Ceiling Fan W/light Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 06:13 PM   #1
Ceiling fan w/light wiring
I had a fluorescent light in my kitchen that was powered by a switch in the kitchen and one in the hallway. I am trying to replace the light with a ceiling fan with light kit. I want the light to be powered by the switches, but the fan to be independent. I followed the instructions in the box for the wiring that I wanted, but I think those were for a 1 switch setup. The white wire from the ceiling that was used with the original light is no longer used and now neither the fan, nor the light work. There is a red wire in the ceiling junction box, but I wasn't sure what to hook up to it. Any help would be greatly appreciated.
Thanks,
Jay
SasquatchUSMC is offline   Reply With Quote
Old 04-01-2012, 06:47 PM   #2
Rewards Points: 6,652
You already have 14/3 or 12/3, depending on what is used for your lighting on that circuit, so that you have a always powered Hot, not a switched hot, but the red could feed another lighting circuit in that room.
Old 04-01-2012, 07:00 PM   #3
I should have said that I'm good at following instructions and that I don't know much about electrical stuff. I don't know what 14/3 or 12/3 are. I imagine they're wires, but I don't know what it means.
Old 04-01-2012, 07:07 PM   #4
At this point, I would suggest either reading up by picking up something like the Black & Decker Complete home wiring guide, or hiring an electrician if you do not feel comfortable.
Old 04-01-2012, 07:49 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
By what you have described you already have a 3 wire in the box what # we don't know. The box should have a black,red,white and bare. The 3 wire is what allows you to control that light from either switch.
If you pull one of the switches out you will see 3 wires connected instead of 2.
So lets surmise that the red and white were hooked to the florescent. On the fan you will need to connect the red to the black and blue on the fan( power fan and light) connect white from fan to white in box. Connect green in fan to bare wire (grounds).
If you want both fan and light on seperate switched I believe you will have to run an additional wire to the box to accomplish that.
Also, THANKS for your service!!
sublime2 is offline   Reply With Quote
Old 04-04-2012, 01:39 PM   #6
Send a message via ICQ to Finpecia
you are right
I am very appreciated
Finpecia is offline   Reply With Quote
Old 04-04-2012, 02:38 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
What do you have the white of the fan hooked up to if you capped the white that was attached to the old light fixture.
A picture of the ceiling box would be a real help. If you can't get a picture, tell us ALL the wires in the ceiling box. It seems as tho the 3 way wiring might run thru the ceiling box.
Old 04-05-2012, 03:12 PM   #8
I appreciated
Old 04-05-2012, 03:45 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
How much more are you worth today than you were yesterday?
Coastal South Carolina
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
wiring ceiling fan: power at fixture teaomer Electrical 2 09-25-2011 07:48 PM
Wiring A Porch Ceiling Fan TFSpaniel Electrical 14 07-22-2011 11:04 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 07:51 AM
