Old 12-18-2011, 07:08 PM   #1
Question
Ceiling Fan turns on porch light
I installed a ceiling fan in my family room and now when I switch the fan from Hi to Medium the motion sensor light on my back porch turns on. It does not happen when I switch the fan from Med to Lo, but happens some of the times I switch from Lo to off. There is no line of sight (or reflected line of sight) between the fan and the light. The fan and the light are on the same circut. Any Ideas ?
jvincent57 is offline   Reply With Quote
Old 12-19-2011, 08:08 AM   #2
ink
DIY Enthusiast
ink's Avatar
Is there a slider switch for controlling the fan speed, or are you using a pull-chain on the fan? If it's a switch, how did you wire it?
inK
Hammer in Hand, Dad on Speed Dial
ink is offline   Reply With Quote
Old 12-19-2011, 10:28 AM   #3
I'm useing the pull chain to control the fan. There is a standard wall switch that is always in the on position.
Old 12-19-2011, 10:34 AM   #4
ink
DIY Enthusiast
ink's Avatar
The wall switch doesn't effect the outside light, though, right? It just switches the fan off and on.
inK
Old 12-19-2011, 11:12 AM   #5
Yes the fan and porch light are on seperate wall switches. The porch light switch is on all the time also because it has a puotocell and motion sensor.
P.S. going to work, will check in later
Two part question on a porch light. J187 Electrical 2 12-07-2011 08:11 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 09:32 AM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 09:14 AM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 01:27 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
