Old 08-02-2008, 12:42 PM   #1
Ceiling fan trouble wiring
I am new to this so please be patient. I am trying to wire a new ceiling fan. Out of the ceiling there are four cables, RED, WHITE, GREEN & YELLOW. From the fan there is BLUE, WHITE, GREEN & BLACK
how do I wire these? I have a 2 button switch one for the light and one for the fan.
Foxtrot_01 is offline   Reply With Quote
Old 08-02-2008, 01:07 PM   #2
Try this
Green to green
White to white
Black to yellow
Blue to red.
If the wrong switch controls the fan then try
Black to red
Blue to yellow
Old 08-02-2008, 01:12 PM   #3
Licensed Electrician
J. V.'s Avatar
I do not know what the ceiling box wires are but the fan wires are as follows.
Blue = Light
White = Neutral
Green = Ground
Black = fan
If the two button switch is existing, this is how it's most likely connected.
Connect the white from the fan to the white in box.
Connect the green from the fan to the bare wire (ground) in the box.
Connect the black from the fan to the red in the box.
Connect the blue from the fan to the yellow in the box.
The yellow or red can be interchanged if the light comes on when the fan should come on.
Old 08-02-2008, 01:16 PM   #4
J. V.'s Avatar
Joed, you type faster than I can.....lol
Old 08-02-2008, 02:33 PM   #5
Ash
Send a message via MSN to Ash
To be sure about the ground : Check with an ohm meter which wire of the fan connects to its metallic parts. This one should be connected to the green from the ceiling
The other wires - try to connect them in one of the ways said above. Try to power it up. See what happens and correct if needed
First connect a lightbulb to red and white or yellow and white to assume which wire is from fan switch and which from light switch. I will call them fan live and light live
1. Fan works very slow and light is dim OR light is ok and fan off
if they both work when fan switch is on then swap light live and neutral
if they both work when light switch is on then move fan wires from light live to fan live / from ceiling neutral to light live / from fan live to ceiling neutral
2. Fan works very slow and light is dim OR fan is ok and light off
if they both work when light switch is on then swap fan live and neutral
if they both work when fan switch is on then move fan wires from fan live to light live / from ceiling neutral to fan live / from light live to ceiling neutral
3. Fan and light controlled by the wrong switches : swap light live and fan live
Ash is offline   Reply With Quote
Old 08-02-2008, 02:57 PM   #6
Send a message via AIM to theatretch85
Ash, you got to realize this forum is mostly USA based users and "Live" is not a term used in the USA. It would help others greatly that you indicate your location, wire colors and functions differ greatly from the UK and the USA and giving someone the wrong info (which may be right in the UK) can be quite dangerous!
theatretch85 is offline   Reply With Quote
Old 08-02-2008, 03:33 PM   #7
Ash
My answer is based on US NEC. 'Live' is equal to 'hot'
Old 08-02-2008, 05:03 PM   #8
Who's a newbie?
fungku's Avatar
However, in USA, you dhouldn't need to test whether or not green is ground. because... green is ground
fungku is offline   Reply With Quote
Old 08-03-2008, 02:08 PM   #9
fungku, Never assume that the person who wired before you did it all according to code. A electricity for dummies book in one hand a and a pair of wire cutters in the other can be a dangerous thing. I've run across situations where circuits were wired with whatever was on hand (zip cord, 2 30A dryers wired off a single 12/3...). A couple of seconds can prevent an unpleasent surprise. pete
petey_c is offline   Reply With Quote
More On This Topic
Hi! I'm Drew Finn and I am here for expertvillage.com. I am a professional home inspector and we are going to show you how to install a ceiling fan today. Okay, now we've got the dates here all set. We hang it on that loop so that we can work on the... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here with expertvillage.com today and we just finished installing a ceiling fan in this house. I just want to take a brief moment and talk about dimmer... Read More »
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Make sure you disconnect all of your power; shut it off at the service panel. Don't rely on any kind of switches or anything like that... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we are hanging a ceiling fan in this house. Now we've already been through all the steps of shutting the power off... Read More »
How to Hang a Fan
How to Hang a Fan by eHow.com
Ceiling fans are a way to help cool a room during the summer and circulate warm air during the winter. They're available in many styles and with numerous lighting options to match the decor of any room. There's no need to hire an electrician to hang a... Read More »
Ceiling fan wiring beezlebub03 Electrical 8 05-05-2008 07:34 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Ceiling Fan Wiring Help! wesr79 Electrical 10 02-28-2008 05:38 PM
My ceiling fan wiring problem jkrodger Electrical 9 08-13-2007 04:51 PM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 06:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
