Ceiling Fan Topic. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 04:18 PM   #1
Ceiling fan topic.
Facts.
1) Have ceiling fan with no light kit.
2)Ceiling fan is controlled by a cirlce knob on wall. Off,high,med,low,extra low.
Home project.
1)Buy a ceiling fan with a light kit.
2)Buy a remote controller to control fan and light.(This is just for if i foget to
turn on the fan or light after i just sat down and reclined back in sofa).
3)Buy a new wall outlet controller.One to control fan and one to control light.
Topics that come to mind.
1)Is my wall outlet a single pole or other?
2) Do i need to run more wires from the wall outlet to the ceiling fan?
Took out the wall outlet and went to see what wires i have.
2 black wires being used. Tied into the 2 black wires from the knob controller.
2 white wires...capped together..not being used.
1 red wire...capped off...not being used
1 copper wire.
Questions i have on topic.
1) Will this wire set up be enough to operate a ceiling fan with a light kit?
If yes to #1...then
2) Will i be able to control the ceiling fan and light both from the wall
and remote?
need 101 is offline   Reply With Quote
Old 10-22-2012, 05:11 PM   #2
Oso954's Avatar
Rewards Points: 1,354
If you want to control it from both the wall and the handheld, then buy a remote set that comes with both. You will replace the current knob controller with the in wall transmitter.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
need 101 (10-22-2012)
Old 10-22-2012, 05:50 PM   #3
Thanks for replying Oso954. I was afraid that setup would be my answer. The one remote i found with great reviews is not a
wall mount receiver type. The receiver goes up in the fan. I'm guessing that with this remote i will only be able to control
the ceiling fan funtions with it alone.
If i cant found a good wall mount remote then i will just go with a manual wall dual setup.
Old 10-22-2012, 06:35 PM   #4
Oso954's Avatar
I'm talking about a set like the one below. 2 transmitters, one receiver.
Most of the fan companies sell a set like this, even it your local store doesn't carry it. They can be ordered. But Lowe's, Home Depot, and larger fan/lighting stores should have something in stock.
If you can't get the set, you can always buy 2 remotes made by the same company and just set them too the same channel. You'll end up with a spare receiver that way.
Old 10-22-2012, 06:58 PM   #5
Thanks again Oso954.
I have seen those at my local stores. I will look at the reviews and see if
i can found a good one. If not i will just go with a regular wall switch for
fan speed and light output. I have put a pic in this to give you a idea of
what i am talking about.
If i go this way, i will just have to remember to turn on the fan or light or
both before i hit the sofa.
Old 10-22-2012, 08:31 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
All the remotes I have installed control both fan and lights.
By having a red wire, you can put in a double switch and control the fan and light separately.
jbfan is online now   Reply With Quote
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
