-   -   Ceiling fan topic. (http://www.diychatroom.com/f18/ceiling-fan-topic-160853/)
need 101 10-22-2012 05:18 PM
Ceiling fan topic.
Facts.
1) Have ceiling fan with no light kit.
2)Ceiling fan is controlled by a cirlce knob on wall. Off,high,med,low,extra low.
Home project.
1)Buy a ceiling fan with a light kit.
2)Buy a remote controller to control fan and light.(This is just for if i foget to
turn on the fan or light after i just sat down and reclined back in sofa).
3)Buy a new wall outlet controller.One to control fan and one to control light.
Topics that come to mind.
1)Is my wall outlet a single pole or other?
2) Do i need to run more wires from the wall outlet to the ceiling fan?
Took out the wall outlet and went to see what wires i have.
2 black wires being used. Tied into the 2 black wires from the knob controller.
2 white wires...capped together..not being used.
1 red wire...capped off...not being used
1 copper wire.
Questions i have on topic.
1) Will this wire set up be enough to operate a ceiling fan with a light kit?
If yes to #1...then
2) Will i be able to control the ceiling fan and light both from the wall
and remote?
Oso954 10-22-2012 06:11 PM
If you want to control it from both the wall and the handheld, then buy a remote set that comes with both. You will replace the current knob controller with the in wall transmitter.
need 101 10-22-2012 06:50 PM
Thanks for replying Oso954. I was afraid that setup would be my answer. The one remote i found with great reviews is not a
wall mount receiver type. The receiver goes up in the fan. I'm guessing that with this remote i will only be able to control
the ceiling fan funtions with it alone.
If i cant found a good wall mount remote then i will just go with a manual wall dual setup.
Oso954 10-22-2012 07:35 PM
1 Attachment(s)
I'm talking about a set like the one below. 2 transmitters, one receiver.
Most of the fan companies sell a set like this, even it your local store doesn't carry it. They can be ordered. But Lowe's, Home Depot, and larger fan/lighting stores should have something in stock.
If you can't get the set, you can always buy 2 remotes made by the same company and just set them too the same channel. You'll end up with a spare receiver that way.
need 101 10-22-2012 07:58 PM
1 Attachment(s)
Thanks again Oso954.
I have seen those at my local stores. I will look at the reviews and see if
i can found a good one. If not i will just go with a regular wall switch for
fan speed and light output. I have put a pic in this to give you a idea of
what i am talking about.
If i go this way, i will just have to remember to turn on the fan or light or
both before i hit the sofa.
jbfan 10-22-2012 09:31 PM
All the remotes I have installed control both fan and lights.
By having a red wire, you can put in a double switch and control the fan and light separately.
