Ceiling Fan Switch Again - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 06:43 AM   #1
Ceiling fan switch again
I have a Casablanca ceiling fan with a variable speed switch that no longer works. I think it is the rheostat and would like to replace that with a 3-speed switch. Can this be done? It's the switch on the fan itself. There is no wall switch, the fan is wired hot. The fan has no light, just the switch chain on 1 side & the rheostat dial on the other. Switch & motor both work fine. The 3 wires from the unit to the switch box are black, blue & white. on the the rheostat there are 2 wires, black & white. The switch has 3, black, blue & red. Original hook up was black supply to black switch, blue supply to white rheostat & black rheostat to red switch. The white supply & blue switch wires were both capped off & not connected to anything.The 3 speed switches I see say 4 wire although 1 said either 3 wire or 4 wire.
ClaytonW is offline   Reply With Quote
Old 09-02-2010, 08:23 AM   #2
Rewards Points: 1,538
No, you cannot simply hook up a 3 position switch where the rheostat was originally and get two speed operation.
You would need some electronics know how and also the fan instructions to find out if you can get two speed fan operation without a new rheostat of the same kind.
Old 09-02-2010, 10:44 AM   #3
Where would I find such a rheostat? Looked at Home Depot & not there.
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-13-2009 11:09 PM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
