Ceiling Fan Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 04:22 PM   #1
Ceiling fan switch
I just purchased a new home. My family room has a ceiling fan,which is always hot(controlled by the chain on the fan). There is wall light switch controlling the power to 2 other outlets (light switch on, outlets are hot; light switch off, outlets off). I want to control the fan from the wall switch and have the two outlets always hot. Is this possible?
Rckman25 is offline   Reply With Quote
Old 07-07-2012, 04:45 PM   #2
Electrician
Rewards Points: 790
Anything is possible. Unless for some reason they ran the switched part of the outlets through the fan box you will need to get a new wire to the switch or down to one of the plugs.
darren is offline   Reply With Quote
Old 07-07-2012, 06:09 PM   #3
Rewards Points: 150
NEC 210.70(A)(1) requires either an outlet or light be controled by a wall switch in each habitable room.
goosebarry is offline   Reply With Quote
Old 07-07-2012, 09:28 PM   #4
I'm new to all this so I apologize but try to bear with me. What should I look for regarding wire?
Old 07-08-2012, 10:02 AM   #5
Rewards Points: 2,516
Your description leaves a lot of variables. The below diagram would do as you want, which is fan controlled by a switch and 2 receptacles ALWAYS HOT.
I do not show ground wires just for ease of drawing
hammerlane is offline   Reply With Quote
Old 07-08-2012, 10:17 AM   #6
As I mentioned above, your description leaves a lot of variables as far as how the existing wiring is configured. Diagram below is functioning as your existing situation is:
power always to fan and controlled by the pull chain and two outlets controlled by a switch.
Old 07-08-2012, 10:19 AM   #7
If the wiring for your situation was as depicted in post #6, the below diagram would do as you want, which is fan controlled by a switch and 2 receptacles ALWAYS HOT.
As you can see from this diagram and the diagram in post #5, they both do as you want but depending on how the existing wiring is configured that makes a difference.
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Adding Ceiling Light To Switch vboz5 Electrical 11 03-13-2009 11:09 PM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
