Ceiling Fan Spins But No Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 06:39 PM   #1
Ceiling fan spins but no lights
Just moved into a new house and removed the old working light fixture for a fan with lights. The fan has a green wire black wire white wire and black white striped wire. I hooked it all up to the ceiling white to white. Black to black green to green and black white striped to red. I assume the green is ground white is circuit the black is fan and black white is light. After hooking it all up the fan spins and turns on off from the switch but no lights. I took the fan off and checked the wiring and also swapped the fan and light wires to see if both were good. The fan works with the other wire now but still no lights. I replaced the bulbs too. Also I opened the switch on the wall and the switch to the fan has 3 wires including the bare metal ground and the left switch for the lights has only 2 including bare metal but I didn't see any loose wire in there to put in. If that's the issue. Any suggestions. It seems the problem is within the fan but I'm not sure how to trouble shoot any further. Even if that switch is bad. When I swapped wires. The good switch should have done lights and no fan. Also the fan is a hunter 22570
Robbyjoeusn is offline   Reply With Quote
Old 04-15-2012, 06:47 PM   #2
I=E/R
a7ecorsair's Avatar
How were the wires connected to the working fixture?
a7ecorsair is offline   Reply With Quote
Old 04-15-2012, 06:53 PM   #3
It was hooked up white to white green to green red to red and the black was capped off. Like I said before. I know black and red wires are hot for lights and fan. And I've tried swapping so both wires in the ceiling check good for power since the fan spun when hooked up to either
Old 04-15-2012, 07:04 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Did you try pulling the pullchains on the fan?
Old 04-15-2012, 07:09 PM   #5
I=E/R
a7ecorsair's Avatar
If the fan will run when connected to either the red or the black but the light never works then the neutral for light is missing somewhere.
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
ceiling & wall lights diynovice1 Electrical 5 07-30-2008 02:10 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Work lights in basement with drop ceiling fw2007 Electrical 2 10-20-2007 09:39 AM
