Old 11-03-2009, 05:58 AM   #1
Default Ceiling Fan Speed Controller Help
Hi all,
Bit inexperienced, need some help installing a new fan controller. Fan is a ceiling fan only, no light.
Currently have a 5-speed selector on the wall that buzzes when switched on and looks about 30 years old...needs to be replaced. There's 3 wires coming out of the wall connecting to it: Red positive, Black negative and a Green/Yellow earth.
Replacing it with a unit: Switch, and below that the variable speed fan controller with the two wires going into the back of the switch - the positive and the loop. 4 circles on the switch in which to put the wires, one with a 'cross' through it.
Question 1 - Am I right to connect the black negative to the loop and the positive to the 'common' circle beneath the switch?
Question 2 - I'm unsure where to put the green/yellow earth wire thats coming from the wall?
Thanks all, if further clarification's needed etc let me know...
Steve0709 is offline   Reply With Quote
Old 11-03-2009, 06:36 AM   #2
A "Handy Husband"
Based on the color coding being used and your terminology, my guess is you are not in North America. Did not a wiring diagram or instructions come with the new fan control? If not you need to get the paperwork, anything else is guesswork.
rjniles is offline   Reply With Quote
More On This Topic
Hi! My name is Adolph Ramirez from Tampa, Florida on behalf of Expert Village, this is how to install a ceiling fan. Make sure you disconnect all of your power; shut it off at the service panel. Don't rely on any kind of switches or anything like that... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here with expertvillage.com today and we just finished installing a ceiling fan in this house. I just want to take a brief moment and talk about dimmer... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we are hanging a ceiling fan in this house. Now we've already been through all the steps of shutting the power off... Read More »
Hi! I'm Chad Smith and I'm a State Certified Journeyman wireman; basically an electrician. I'm here today with expertvillage.com and we just finished installing this ceiling fan. Now all we have to do is go out and flip the power back on and come back in... Read More »
Hi! I'm Drew Finn and I am here for expertvillage.com. I am a professional home inspector and we are going to show you how to install a ceiling fan today. Okay, now we've got the dates here all set. We hang it on that loop so that we can work on the... Read More »
Hunter Ceiling Fan: Won't do high speed ConstantChange Electrical 4 09-28-2009 05:00 PM
Old ceiling replacement idsp General Discussion 12 07-25-2009 12:48 PM
Fan Speed Controller Application GooberFish Electrical 2 03-20-2009 01:46 PM
ceiling fan-wall transmitter for light and fan speed control stan 41943 Electrical 5 03-03-2008 06:27 PM
Speed control of ceiling fan pjpjpjpj Electrical 7 03-19-2007 05:13 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
