Ceiling Fan Speed Control - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 01:16 PM   #1
Rewards Points: 22
Ceiling Fan speed control
My ceiling fan suddenly only works on high speed regardless of the pull chain speed control position. It is direct wired w/o a wall switch, otherwise I'd substitute in a wall speed control. Are internal fan speed controls replaceable? I assume that is what burned out.
Any suggestions would be appreciated . . . .
Paul_NJ is offline   Reply With Quote
Old 11-28-2010, 03:32 PM   #2
Rewards Points: 58
It should have a wall switch, but we will leave that argument for later. Just replace the pull chain switch.
Old 11-29-2010, 07:20 AM   #3
Rewards Points: 22
Just replace the switch? I've never seen the internal wiring diagram of a ceiling fan, but it is a three speed unit. Is the chain switch a simple spst switch (which I know I can get anywhere) , with circuitry in the fan that interprets the toggling of the switch, or a multiposition switch (and where would I get that?) I guess I could simply pull the switch and test it with a VOM. Is it usually the switch that burns out, or the electronics the switch actuates?
I've installed many a ceiling fan, but never gone inside the controls before. This one is like new . . . hate to toss it if a simple part will do.
Old 11-29-2010, 12:23 PM   #4
Rewards Points: 58
If it's new take it back and get a new one. A whole new fan.
If its not that new remove the old switch and mark down how the wires go back together. Take the switch to the store and get one just like it. Install it and then have a beer.
Or trash the fan. Its you're call after all. We can only give advice. I would fix it. Thats just me.
Variable speed pumps and cycle control valves NHMaster Plumbing 0 02-25-2010 06:55 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 03:06 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Wiring A Ceiling Fan, Receptacle, and Outside Light merlin6984 Electrical 9 03-26-2009 10:52 PM
