Ceiling Fan Speed Control - Electrical - DIY Chatroom Home Improvement Forum
Old 05-26-2012, 10:12 PM   #1
I have a 2-wire, 5 speed, transformer based ceiling fan motor control; the Black wire is labeled F, and the White wire is labeled L . The fan it controls is 56 inch, 3 metal blades, with no light. What is the proper way to wire this?
Boscohearn is offline   Reply With Quote
Old 05-26-2012, 10:35 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
what do the instructions say?
Just assuming, I would say wire labeled "F" goes to the fan, and the wire "L" is the line side.
Old 05-27-2012, 10:04 AM   #3
Rewards Points: 240
Connect the two wires (F&L) to the supply and pull the chain to select the desired speed. Seriously. Look at the wiring diagram.
Old 05-27-2012, 01:36 PM   #4
Rewards Points: 6,652
Now, that would be too hard, especially that you have the Internets to do it for you.
Hunter Ceiling Fan & Light control #27182 slrholmes Electrical 23 03-28-2014 05:46 AM
DC Speed Control Questions korovyov Electrical 6 05-09-2011 04:48 PM
Ceiling fan speed Robert Radmore Electrical 1 04-30-2011 06:14 PM
Remote Control Ceiling Fan - switch required? bvbellomo Electrical 7 11-10-2010 08:07 AM
Variable speed pumps and cycle control valves NHMaster Plumbing 0 02-25-2010 05:55 PM
