Old 06-26-2007, 04:52 PM   #1
Ceiling Fan Shimmies
hello,
i installed a ceiling fan alittle over a year ago, and i noticed just the other day that it is shaking alittle on med and high speeds, while turning counter-clockwise. clockwise rotation is fine on all 3 speeds. the base of the fan, where it meets the ceiling is not moving, just the motor itself. i know the motor is mounted in rubber, to compensate for vibration, so is this ok? i mean its not wobbling, just a shimmy. it was fine when i first installed it i checked all the fan blades, and they are tight, what could have changed? and why does it shimmy only when turning counter-clockwise?....bob
bobo is offline   Reply With Quote
Old 06-26-2007, 04:54 PM   #2
Master Electrician
JohnJ0906's Avatar
Did you check all the screws, the ones holding blades to brackets, and the ones holding brackets to motor?
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 06-27-2007, 12:04 AM   #3
johnj,
i checked all the screws on the blades and on the motor, and they were tight. i snugged them a tad more tho, and still a slight shimmy. only thing i can think to do, is to remove the blades, and cover, and check the screws that hold the motor to the monting bracket. any other ideas?...bob
Old 06-27-2007, 08:44 AM   #4
Licensed Pro
If the counter-clockwise rotation is the reverse flow (air blows toward ceiling), then this is not unusual. The air bouncing off the ceiling, usually only a foot or two above the fan, will cause the fan the wobble as air is directed back toward the fan.
Old 07-03-2007, 01:38 PM   #5
J. V.'s Avatar
The fan needs trimming. Google "trim a ceiling fan". You should get plenty suggestions on this subject.
Old 07-03-2007, 11:52 PM   #6
hello, j.v.,
i did a search on "trim a ceiling fan". all i found was talk about the cosmedic trim for the fan. pls explain. do u mean shim to balance the fan?...bob
Old 07-04-2007, 03:02 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Check the "box" that the fan is attached to. A poorly installed box, or improperly attached box, or simply, the wrong kind of box, can cause a ceiling fan to wobble..........
Example of proper box installation: http://www.doityourself.com/stry/h2addafan
Alternative anti-wobbling method (if box install is correct):
http://www.ronhazelton.com/tips/Ceil...ancing_Kit.htm
- Build Well -
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
lowering ceiling to 8 feet level mirico Carpentry 4 10-24-2009 09:24 AM
ceiling fan support triplnikl Carpentry 5 03-06-2009 04:47 PM
Rod Lengths for Ceiling Fans and Mini Pendants Not Sure Electrical 6 10-25-2006 12:23 AM
