-   -   Ceiling Fan Shimmies (http://www.diychatroom.com/f18/ceiling-fan-shimmies-9442/)
bobo 06-26-2007 03:52 PM
hello,
i installed a ceiling fan alittle over a year ago, and i noticed just the other day that it is shaking alittle on med and high speeds, while turning counter-clockwise. clockwise rotation is fine on all 3 speeds. the base of the fan, where it meets the ceiling is not moving, just the motor itself. i know the motor is mounted in rubber, to compensate for vibration, so is this ok? i mean its not wobbling, just a shimmy. it was fine when i first installed it i checked all the fan blades, and they are tight, what could have changed? and why does it shimmy only when turning counter-clockwise?....bob
JohnJ0906 06-26-2007 03:54 PM
Did you check all the screws, the ones holding blades to brackets, and the ones holding brackets to motor?
bobo 06-26-2007 11:04 PM
johnj,
i checked all the screws on the blades and on the motor, and they were tight. i snugged them a tad more tho, and still a slight shimmy. only thing i can think to do, is to remove the blades, and cover, and check the screws that hold the motor to the monting bracket. any other ideas?...bob
HouseHelper 06-27-2007 07:44 AM
If the counter-clockwise rotation is the reverse flow (air blows toward ceiling), then this is not unusual. The air bouncing off the ceiling, usually only a foot or two above the fan, will cause the fan the wobble as air is directed back toward the fan.
J. V. 07-03-2007 12:38 PM
The fan needs trimming. Google "trim a ceiling fan". You should get plenty suggestions on this subject.
bobo 07-03-2007 10:52 PM
hello, j.v.,
i did a search on "trim a ceiling fan". all i found was talk about the cosmedic trim for the fan. pls explain. do u mean shim to balance the fan?...bob
AtlanticWBConst. 07-04-2007 02:02 PM
Check the "box" that the fan is attached to. A poorly installed box, or improperly attached box, or simply, the wrong kind of box, can cause a ceiling fan to wobble..........
Example of proper box installation: http://www.doityourself.com/stry/h2addafan
Alternative anti-wobbling method (if box install is correct):
http://www.ronhazelton.com/tips/Ceil...ancing_Kit.htm
