Ceiling Fan Screw Hole Threading Issues - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2013, 10:55 AM   #1
braves22's Avatar
Ok first let me start off by saying I wasn't sure where to put this question.
Anyways here goes...I am installing a ceiling fan and I got down near the end of the project BUT I am installing the blades and 1 screw hole on a single blade (holds 2 screws) just won't budge AT ALL...
So I guess what I am curious about is if anyone has any tricks they know of so that I can either go buy another screw or get it through...the man thing I am looking at is that it seems as though there are no threads inside the hole at all...someone help
braves22 is offline   Reply With Quote
Old 01-24-2013, 10:56 AM   #2
braves22's Avatar
Also let me preface by saying I don't have a tap kit and for a fan that was less than $100 cost, I don't think it makes sense to pay at least $50 for a kit
Old 01-24-2013, 11:09 AM   #3
Rewards Points: 256
Was the hole tapped at all? If so you could probably clean it up with a couple sacrificial screws. In a pinch i made a self tapping screw with a dremel cut-off tool by removing what looks like a 1/4 pie when viewing the screw on end.
Some self tapping screws (and taps for that matter) have a similar design.
I think this answers your question, but my main suggestion is that you take the two components to the store you bought it at and get new pieces. They will ask that you take the whole fan in, just tell them no, you will win.
michaelcherr is offline   Reply With Quote
Old 01-24-2013, 11:16 AM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Take one of the screws to the store and just buy the size tap you need. I have had that before where one hole was not tapped and usually just a 10-32 thread. Or just take the fixture back to the store and get another one.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
oh'mike (01-24-2013)
Old 01-24-2013, 11:21 AM   #5
braves22's Avatar
Thx guys...
I'd rather not take the entire fixture or the problem area as it is where the fan blades screw to the big housing portion...
From the looks and feel it looks like they completely missed "threading day" on that particular hole...so yeah I probably would need a tap...never done it before though so what should I look for?
The screw is one of those blade iron armature screws and doesn't give me the size in the parts guide...
But yeah it really stinks bc it's the only hole of 10 that wasn't done correctly.
So just take the screw in and see if someone in the store could help me?
Old 01-24-2013, 11:24 AM   #6
take the screw with you to a hardware store and purchase a single tap in that size. you don't have to buy a whole set.
Old 01-24-2013, 11:25 AM   #7
jbfan's Avatar
Rewards Points: 420
Originally Posted by braves22 View Post
Thx guys...
Just take the screw with you and pick up nuts until you find the right one.
Chances are it will be metric.
Old 01-24-2013, 11:25 AM   #8
Rewards Points: 256
Ok, i thought the hole was on the blade bracket. Its on the main fan unit.
3 options:1. take the unit in for an exchange. 2. Buy a tap for about $5(dont need a whole set)
3. Buy/make a self tapping screw of the correct thread form and hope thats enough to chase the threads.
Old 01-24-2013, 11:37 AM   #9
braves22's Avatar
Maybe this would help better clarify:
http://www.hunterfan.com/uploadedFil...-02-080(1).pdf
The screw is the blade iron armature and they are placed through a front bracket of that middle piece in the blade assembly and placed through the 6th piece down on the hanger assembly at the top of it.....that is where the screw holes are and I am having the issue....
Does that make sense?
I was just curious what the best options would be and I just had no idea what type/size of screw it was and what would be my best option....
Just a bit more than frustrating when you think you're close to completion of putting something together only to get stopped in your tracks.
Old 01-24-2013, 11:42 AM   #10
Rewards Points: 1,294
Call the 800 number on the install sheet. Hunter is a good company. Explain to them what happened and I bet in a couple days you will have a new part.
danpik is offline   Reply With Quote
Old 01-24-2013, 11:49 AM   #11
Rewards Points: 130
Take it back! I know its harder to do, but I would take it back no matter what.
Then, when I got to the store I would be looking for a better quality fan. ( I have always liked Hunter) Insist on a discount for your troubles.
If you bought this fan from where I think you did, they will have no problem with reimbursing you for your troubles. Just ask and be firm.
Ps...........Make them check the replacement before you leave the store. Especially if you get the exact model you have now. Could be many fans with this same issue.
Old 01-24-2013, 12:27 PM   #12
Rewards Points: 4,796
Just get a few tapered self tapping metal screws and try them until you get the right size to catch, then ream it in. A hex head will work best. It can be painted black later if you need.
jeffnc is offline   Reply With Quote
Old 01-24-2013, 12:29 PM   #13
If you want to take it back to a big store like Lowes or Home Depot, you don't necessarily need to take down the whole fan. You could just remove the part that is the problem, take it back, have them open a new box, give you the replacement part from the new box, put your bad part in the box and have them return that one. Same result, you just swapped it out. They've done that for me before.
The Following User Says Thank You to jeffnc For This Useful Post:
Hardway (01-24-2013)
Old 01-24-2013, 01:07 PM   #14
braves22's Avatar
The problem is, the way the fan is assembled it is pretty much the whole fan as this is the top part of 3 pieces put together and it's just below the canopy...so it would be a HUGE pain...
Maybe ill see if I can get someone to figure out what I need to thread the screw into the blade assembly hole
Old 01-24-2013, 01:16 PM   #15
New Fan TAKE IT BACK AND GET ANOTHER ONE!
Hardway is offline   Reply With Quote
The Following User Says Thank You to Hardway For This Useful Post:
rrolleston (01-24-2013)
Ceiling fan - Downrod won't screw in all the way tima2381 Electrical 8 05-02-2012 02:57 PM
Ceiling issues in old home tbarker13 Drywall & Plaster 5 01-22-2012 08:53 PM
ceiling hole above stove lolita Kitchen & Bath Remodeling 1 11-07-2011 04:57 AM
Ceiling fan remote issues Richo Electrical 7 06-06-2011 09:09 PM
Ceiling fan wiring issues cmlcsu Electrical 3 07-02-2010 02:38 PM
