Ceiling Fan Scraping - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2009, 07:22 PM   #1
On a low level, everything is fine. But when i put it on high or medium, the brackets of the blades very slightly scrape against the motor housing on one side. Perhaps my ceiling or the fan box is not completely level. What can I do to have that side lowered?
I have a Harbor Breeze New Haven model NH52ABZ5C.
thanks
picsaro is offline   Reply With Quote
Old 05-28-2009, 05:59 AM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Post a Pic and a little History. Is this a new installation in a rated ceiling box or has the Fan been installed to replace a ceiling light?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-28-2009, 10:28 AM   #3
Rewards Points: 338
picsaro, Put a level up on the ceiling and see if it's level. Is your fan balanced? pete
petey_c is offline   Reply With Quote
Old 05-28-2009, 01:10 PM   #4
Tool Geek
PaliBob's Avatar
Is this a pic of your fan?
Is it new?
Does it replace another fan?
Is the ceiling box metal or plastic?
When you stand on a stepladder and with both hands rock the blades up and down can you detect any movement in the housing?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-28-2009, 02:18 PM   #5
It's obviously not sitting flush in the bracket.
It's not rocket science. Look at it and determine how to correct it.
220/221 is offline   Reply With Quote
Old 05-28-2009, 08:32 PM   #6
That is the fan. Ceiling box is metal. It replaced another fan, but previously there was no box- it was just screwed into a joist. The ceiling is slightly not level. Can i compensate for that by adjusting the motor somehow? It is a ball fits into the bracket, so im not sure how i could adjust that.
thanks
Old 05-28-2009, 10:33 PM   #7
Rotate the ball so it drops into the slot.
Old 05-29-2009, 09:17 AM   #8
the ball is in the slot. that appears to be level and secure. but because the ceiling is not level, it is causing the housing to be lower on one side, thus making the blade bracket scrape it. so i either need to somehow reposition the ball in the socket or raise the ceiling slightly. any suggestions are appreciated.
Old 05-29-2009, 12:02 PM   #9
Tool Geek
PaliBob's Avatar
Originally Posted by picsaro View Post
...... but because the ceiling is not level, it is causing the housing to be lower on one side, thus making the blade bracket scrape it. .........
Is the ceiling wavy or does it slope?
From the pic, it looks like the housing is a little more than 12" wide. Across that distance how much out of level is the ceiling? How about a pic?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-29-2009, 01:30 PM   #10
Rewards Points: 506
Send a message via AIM to theatretch85
Are these brackets by chance the little plastic shipping stoppers that must be removed prior to installation? Every new ceiling fan I have installed has had the plastic stoppers screwed into the fan motor housing to prevent it from being damaged while being shipped/transported.
theatretch85 is offline   Reply With Quote
Old 05-29-2009, 06:12 PM   #11
Ahhh. I get it. I didn't look closely at the pic.
You can't install a fan of this style on a sloped ceiling.
Get a fan with a 4" to 5" canopy.
Old 05-30-2009, 09:17 PM   #12
the ball is in the slot...
lol
anyway I suspect that a smaller canopy or a higher-projecting fan would do it...
erics37 is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Ceiling Fan Scraping picsaro HVAC 1 05-27-2009 06:23 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
