Ceiling Fan - Romex / Junction Box Look Over - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2013, 10:59 PM   #1
Ron Paul 2012
Installed a ceiling fan in 2 of the rooms at my mom's with no problem. However, the last one had a rafter running center of the room, so I had to move the mount over to the next section leaving the electrical short.
I picked up the Romex, Junction box and wired it up, but I am unsure about this being the most practical and safe way to go about it. I included some pictures of the job and was hoping for some feedback. Also, the house is older with no ground.
Ceiling Fan - Romex / Junction Box Look Over-imag0090.jpg   Ceiling Fan - Romex / Junction Box Look Over-imag0092.jpg
HandymanCA is offline   Reply With Quote
Old 03-05-2013, 11:03 PM   #2
Rewards Points: 13,968
Pictures did not come out.
You should have installed a juntion box that is assesable with a cover and a another piece of wire. And splices have to be in an enclosure.
Old 03-05-2013, 11:08 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by HandymanCA View Post
...so I had to move the mount over to the next section leaving the electrical short.
Looks fine from here.
You added a single gang box, made up your "extension" there and ran it to the new box for the fan. Good to go. No extra points are given for pretty.
Old 03-05-2013, 11:10 PM   #4
Ron Paul 2012
Pictures should be showing now. It was on the other side of the rafter, so I went over and stapled it with the existing staple.
Old 03-05-2013, 11:13 PM   #5
Should have drilled a hole and gone through the rafter to be legal, that way no one can step on it.
NJMarine (03-06-2013)
Old 03-05-2013, 11:19 PM   #6
Ron Paul 2012
I'm thinking of going back up in the attic and drilling through, I think it will look more cleaner and not be a big hoop over the rafter. Also, will sleep better at night making sure I did it right on my Mom's place.
The Following User Says Thank You to HandymanCA For This Useful Post:
sirsparksalot (03-05-2013)
Old 03-05-2013, 11:21 PM   #7
Rewards Points: 512
Points deducted for too much sheathing in the jbox, if that is a jbox; I assume there's a cover for it?
As far as drilling holes ("to be legal") where's the code there? If it's not within, I believe, 4' of attic entrance (area served by storage), isn't ok to run across the beams?
Old 03-05-2013, 11:23 PM   #8
Rewards Points: 512
And strip back the sheathing to about 1/4" inside that blue box; you'll be able to make better connections, and will be easier to work on in the future.
Old 03-05-2013, 11:32 PM   #9
Rewards Points: 332
If that is an engineered truss, drilling it would likely be a violation due to the structural integrity being compromised.
sgip2000 is offline   Reply With Quote
The Following 2 Users Say Thank You to sgip2000 For This Useful Post:
silversport (03-06-2013), sirsparksalot (03-05-2013)
Old 03-05-2013, 11:49 PM   #10
Rewards Points: 512
Ok, an NEC citation is needed here, please?
Is there a code violation in running cable across the beams in an attic, and please cite the article.
I am believing that any space outside of a 4'-6' area of the access hole is NOT a code violation. If it's within this area, then storage is an issue, and it would be a violation.
I have no citations to back up my beliefs; they come from my experience with Journeymen and Masters.
Old 03-06-2013, 12:30 AM   #11
320.23
“A) Cables Run Across the Top of Floor Joists. Where run across the top of floor joists, or within 2.1 m (7 ft) of the floor or floor joists across the face of rafters or studding, the cable shall be protected by substantial guard strips that are at least as high as the cable. Where this space is not accessible by permanent stairs or ladders, protection shall only be required within 1.8 m (6 ft) of the nearest edge of the scuttle hole or attic entrance.”
clydesdale is offline   Reply With Quote
Old 03-06-2013, 12:50 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Technically the install is non compliant. You are not allowed to extend an ungrounded circuit.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following 4 Users Say Thank You to rjniles For This Useful Post:
clydesdale (03-06-2013), Jim Port (03-06-2013), sirsparksalot (03-06-2013), stickboy1375 (03-07-2013)
Old 03-06-2013, 05:51 AM   #13
Rewards Points: 2,516
You could of used one of the saddle boxes to mount onto the joist.
Ceiling Fan - Romex / Junction Box Look Over-saddle-2.jpg
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
ddawg16 (03-07-2013), jbfan (03-06-2013)
Old 03-06-2013, 10:30 AM   #14
Licensed electrician
Rewards Points: 1,758
Like RJ said, the biggest problem is the extension of an ungrounded circuit.
Old 03-06-2013, 10:40 AM   #15
Rewards Points: 512
Originally Posted by clydesdale View Post
320.23
Ah yes, thank you.
Bring romex out hole in drywall to enter junction box?? Minus08 Electrical 16 01-17-2012 10:47 AM
Ceiling junction box for fluorescent light pomelo Electrical 4 12-01-2011 04:09 PM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
ceiling junction boxes DangerMouse Electrical 8 07-17-2008 06:44 PM
