Ceiling Fan Remote Coming On By Itself - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 12:44 PM   #1
ceiling fan remote coming on by itself
We had an electrician install 2 ceiling fans with remotes. Both come on by themselves at different times. Sometimes the light, sometimes the fan. Any ideas?
wb4rt is offline   Reply With Quote
Old 07-11-2011, 01:24 PM   #2
Rewards Points: 6,652
Most likely the receivers are either bad, or picking up stray frequencies. Could try by disconnecting one, or both, and see what happens. If they are not on different channels, or there is a older type of cordless phone, or even near a airport, military base, or ham operator, it can cause this type of behavior.
Old 07-11-2011, 03:08 PM   #3
Electrical Contractor
kbsparky's Avatar
How close are you to your neighbors?
Usually this is an indication that the remotes need to have the frequencies changed, since one or more of your neighbors is probably turning on his fan, and yours is responding to his remote.
Betcha you are wrecking havoc with his fan(s) as well!!
-KB
Old 07-11-2011, 03:26 PM   #4
No one lives within 1/4 mile of the house.
The electrician had to cut the original light kit wires and install different light kits and remotes. I'm thinking the connections may need to be checked, but just wondered if anyone had any experience. I can exchange the remote kits, just not likely I got 2 bad ones.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Retrofit a Ceiling Fan Remote DIYerIT Electrical 7 09-03-2010 10:49 PM
Help. Finding single gang ceiling fan light/fan switch with remote viper Electrical 4 08-30-2010 05:54 PM
How to fix a pot light coming out of the ceiling xcell General DIY Discussions 4 07-22-2009 10:04 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
