Ceiling Fan Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 05:50 PM   #1
Rewards Points: 55
Question
Ceiling fan problems
We are having some odd problems with two of our fans. They randomly stop working (while running), maybe once or twice a month. Heavy amount of fiddling with the controls (on/off, etc) eventually get them going again, but somtimes it takes weeks of fiddling with the controls before they get going again. Once they get going, they may work again for months. There doesn't seem to be any rhyme or reason to it. We almost replaced them thinking they went bad.
1. They are two different brands (Minka Napoli and Hunter - forget the model) one with separate light/fan controls, one with single (transmitter based). Lights always still work. Two different rooms. They do not die at the same time. The minka fan usually runs constantly during the summer, whereas the hunter one has more modest usage.
2. When they are "dead", you can feel them humming as if they are trying to kick in. Sometimes they move a tiny bit. Manually trying to get them going doesn't help. With the minka you can hear the built-in receiver clicking and changing speeds, meaning that it received the command, but it doesn't necessarily transalte into movement. Touching both fans in this "dead" state you can feel them vibrating slightly, especially at top speed.
Does anyone know what could be causing this? I find it odd that two fans in two different rooms from two different manufacturers have started displaying same issue. Is it just a coincidence and is this a sign of two dying units?
injvstice is offline   Reply With Quote
Old 10-30-2010, 09:37 PM   #2
Electrical Contractor
kbsparky's Avatar
Check to ensure your reversing switch is not stuck in the middle. Otherwise, you may have a loose wirenut or connection inside of the fan cup.
-KB
Old 11-01-2010, 11:17 PM   #3
Rewards Points: 55
The minka doesn't have a reverse switch, it's all electronically controlled. But I will check. as of now, they are both working again! Since the minka is responding to the controls and it's trying to start (I can hear it changing speeds when I use the remote control, even though it doesn't get moving) I kinda' doubt it's a lose wirenut..
Could it be accumulation of dust or something inside the fan? I suppose next time it gets stuck I can use some compressed air. But I don't know what area is most likely to be affected by dust in this way.
it could be ghosts, you know.. halloween and all.
Tags
ceiling fan
install ceiling fan in a suspended metal stud ceiling? amp3d Remodeling 2 09-10-2010 07:55 PM
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 10:55 AM
ceiling fan installation problems HELP! ldld2320 Electrical 12 03-15-2010 10:59 AM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 03:29 AM
Problems refinishing ceiling aumanpj Remodeling 8 01-18-2010 11:58 AM
