Old 11-24-2008, 05:18 PM   #1
Ceiling Fan Problems
I'm trying to put up a new ceiling fan but the house has old wiring(just black and white.) Power comes in at the fan and goes to the switch(end of run.) Can I still use the ceiling fan buy capping off the ground??
DIYer69 is offline   Reply With Quote
Old 11-24-2008, 05:21 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
Is the existing wiring BX. I would connect it to the box and the ground on the bracket from the fan.
Old 11-24-2008, 05:22 PM   #3
It is not armored BX, it is the old Fabric-sheathed cable. The box isn't grounded either.
Old 11-24-2008, 05:25 PM   #4
buletbob's Avatar
what is around the wire to protect it before it connects to the box. is it a metal casing or is it a soft waxy fabric ?.
Old 11-24-2008, 05:32 PM   #5
It's the old fabric-sheathed cable.
Old 11-24-2008, 05:45 PM   #6
My License Ain't 4 Sale..
Yes. You can use the fan. Ideally you would rewire the house, but since that is unlikely, you can put the fan up, being extra careful to make sure you have good connections that aren't likely to come loose and energize the metal of the fan.
Old 11-24-2008, 05:52 PM   #7
Thank you for the information. You have been very helpful!!
Old 11-24-2008, 06:43 PM   #8
joed's Avatar
I agree. Not much of a hazard here. How many people can reach a fan on the ceiling?
Old 11-25-2008, 12:28 PM   #9
You do need to make sure that the box is rated for a fan, and that it is attached between or to joists propertly, or it (the fan) may pull the whole thing down!
KE2KB is offline   Reply With Quote
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
Ceiling Fan Problems JeremyS04 General Discussion 10 08-12-2007 08:02 PM
Ceiling Light problems David Cleere Electrical 9 07-17-2007 07:13 PM
