Ceiling Fan Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2013, 09:38 AM   #1
Ceiling fan problems
My ceiling fan does NOT have a dimmer switch or a remote control, however, the light bulbs seem to switch off and back on again at times. Any ideas what might be going on?
vdammer is offline   Reply With Quote
Old 01-15-2013, 09:47 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 638
Ayuh,... There's a Loose connection in it somewhere,... Which is a Fire hazard...
Old 01-15-2013, 09:49 AM   #3
Rewards Points: 13,300
Loose wire? At the very top of the fan where it mounts to the ceiling there should be a red or blue wire that's connected to the incoming black wire that powers the light.
It could also be the switch that the cord to power the light on and off is attachted to is going bad.
http://www.bing.com/images/search?q=...BA2E13&first=1
Old 01-15-2013, 11:17 AM   #4
Rewards Points: 578
i agree, check your connections. Oh yeah, and turn off the breaker before you touch that wire...
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 01-15-2013, 12:45 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
What size bulbs are you using?
Fans have a current limiter to keep the size of the bulbs below 60 watts each.
Installing Ceiling Fan Electrical Box (Old Construction) jtslue24 Electrical 7 09-16-2012 01:58 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
ceiling fan installation problems HELP! ldld2320 Electrical 12 03-15-2010 11:59 AM
Problems refinishing ceiling aumanpj Remodeling 8 01-18-2010 12:58 PM
