02-12-2012, 10:53 AM
#31
Ceiling Fan Problem, please help
can you spread those wires out some and take another picture or two
02-12-2012, 10:56 AM
#32
sure what do you want me to take a pic of? what do you want to see?
02-12-2012, 11:03 AM
#33
The wires at the outlet...kind of spread them apart so its easier to see what goes where. Are there any cables that come in from the bottom of the outlet box.
I asked how many wires are under the wire nut I circled. You said
""no there are 4 wires . 3 black and 1 white. the one that is B goes with the white up to the right. one black goes up to the left and the other black is connected to A""
Above you say there are 3 black wires under the wire nut but you only described 2 blacks(one black goes up to the left and the other black is connected to A) where
does the other black go? I just don't see 4 wires under that wire nut.
02-12-2012, 11:16 AM
#34
UAW SKILLED TRADES
1.) Which white and black at the receptacle is the incoming power cable?
2.) You show only a single cable at the ceiling fan and a single cable at the light switch ?
3.) You mentioned by-passing the switch. If the cable coming into the ceiling fan is bypassing the switch is it connected to the incoming power cable at the receptacle? If so please point out in your pictures where that cable (black and white) going to the ceiling fan is connected at the receptacle.
4.) Also are you using wire nuts at the fan? Your just showing wires sorta twisted together ... make sure those connections are in wire nuts.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
#35
Since the switch was wired as part of a switch loop, you cannot wire the fan directly to the switch. Instead, you'll need to wire it in to the outlet box. But first, you should confirm that you have enough box capacity in the outlet box to handle the new wires. Some metal boxes have their capacity stamped on them. Do you see any markings on outlet box along the lines of "XX Cu. in."? If not, pull out a ruler and measure the depth of the box. Also check back before going ahead and wiring this up. There's a chance you'll need to replace the box.
As for the actual wiring, am I correct in recalling that you would like the switch to control the fan instead of the outlet? If so you'll wire this up by connecting the new white wire to the white wirenut group on the left. For the hot, you'll remove the black wire going into the outlet at B, and wirenut it to the new black wire. To restore power to the bottom of the outlet, you can do one of the following: 1) buy a new outlet with the tab between the screws, 2) add an additional pigtail from the group wirenutted on the right to the bottom screw (may require a larger wirenut), 3) add a wire from the back entrance of A to the bottom screw or back entrance at B. I'm not a fan of the back stabs or unnecessary pigtails, thus the reasoning behind my ordering. For the ground, you'll remove the green wire going to the outlet. Finally, you'll wirenut the following together
1) The three old grounds (assuming they didn't snip one or more back)
2) The new ground
3) A green/bare pigtail going to the outlet screw
4) A green/bare pigtail going to the grounding screw on the box
You may want to break these up between 2 wirenuts with an additional pigtail.
As an additional note, if you have a ground wire coming in to the switch box, it should be pigtailed to both the switch's ground screw and the ground screw in the metal box.
Reason: Updated for additional wire
02-12-2012, 11:18 AM
#36
there were 4 wires total, 3 coming in from somewhere and the one going to A.
I spread them apart so you can see where they go.
B goes up with the white that was connected at the wire nut
1 one black goes down with a white
1 black goes up with a white
the 2 whites (one up and one down) are wire nutted togther and have a pigtail which is then plugged into the bottom of the outlet
02-12-2012, 11:21 AM
#37
yes i used wire nuts, just took them off for the pic. i ran a wire from my basement directly to the fan to test the power and the fan to make sure i didnt wire the outlet wrong. i re wired the outlet to how it was so i could send pics.
02-12-2012, 11:25 AM
#38
1) The two old grounds (assuming they didn't snip one back)
2) The new ground
thanks for the writeup, the box is 2in deep
02-12-2012, 11:27 AM
#39
So which wire is incoming power, the upper left or the lower right? Nevermind, I see you already answered it while I was typing.
Also, do the walls of the box go straight back, or is part of the box under the wall?
02-12-2012, 11:33 AM
#40
power is coming in from the black from the top left of the box
02-12-2012, 11:37 AM
#41
the box doesnt go straight back. it looks like it goes to the left and right about a inch or so so it is not a complete rectangle box
#42
UAW SKILLED TRADES
Deleted to avoid confusion
Stubbie
02-12-2012, 11:40 AM
#43
Look at this picture
no,the other end of the wire that is connected to the ceiling fan is still in the attic. the pics you have seen of the wiring is all original like how it was before i started the project.
i did at one point run the wire from the fan to my basement as it was over 20ft long and i had a easy access point just to test out the fan before i did wire anything because i didnt want to wire to the wrong spot and have to re do it all, thats when i realized the fan was not working at all when i bypasses everything
02-12-2012, 11:47 AM
#44
UAW SKILLED TRADES
Ok .. you are never going get this solved till you understand what we are asking.
We have to know what black and white wires in that receptacle box are incoming power ... forget the up and down description. Point them out in the picture.
Then I need to know where the two wires in the ceiling fan cable are connected.
Stubbie
02-12-2012, 12:06 PM
#45
To the OP......Correct me if I missed something but I just read every one of your posts and I don't see where you mentioned that the fan will in fact run. You are trying to troubleshoot with 2 unknowns here, will the fan run and is the wiring correct.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
