Ceiling Fan Power - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2010, 08:58 PM   #1
ceiling fan power
My ceiling fan is wired continious hot off my line that feeds my furnace. So when my ac turns on it dims and I have replaced 4 fan motors due to this Should I pull off a outlit in a room or switch or I am going to be running 12-2 off a 20 amp to my bathroom which will be a closet light 2 outlits a 3 bulb light and exhaust fan. What would be the best thing to doo I can easly access the wire.
sjthompson is offline   Reply With Quote
Old 09-01-2010, 06:12 AM   #2
Your FAN "dims"? Is this a bathroom exhaust fan you are talking about?
I am NOT a code expert, but your current situation and potential solution sound a little suspicious to me. I would not be surprised to find that a furnace is required to be on it's own circuit. I understand, also, that there are codes requiring bathroom cirucuits, GFI, what can be on them, etc. How is your bathroom currently wired?
In my experience, access of the wire is dependent on the house and wall construction.
oberkc is offline   Reply With Quote
Old 09-01-2010, 08:02 AM   #3
Just call me Andrew
Rewards Points: 1,020
You cannot use your bathroom outlet circuit to feed a ceiling fan in another room.
Andrew
secutanudu is offline   Reply With Quote
Old 09-01-2010, 08:16 AM   #4
Rewards Points: 1,532
Run a new branch circuit to the furnace and/or one to the AC (is this easy given the distance?) leaving the circuit to the bathroom and fan intact and passing by the furnace.
If the fan dims far and long enough to damage its motor, there is something else wrong with the circuit, like a loose connection.
Old 09-01-2010, 10:00 AM   #5
Well for one its on a 15amp circuit with 14-3 wire it is a old house built in 1974 so alot of stuff is not to code. I am going to run the dedicated to the master bath cause now it it 15 amp to bath and 3 plugs in bedroom and 2 in living room like I said shoty wirng in old homes, I guess it didn't matter back then. lol I belive that a ac blower motor and circuit board will draw more than 15amps I don't know though.
Old 09-01-2010, 12:40 PM   #6
If the bathroom is going to get the new circuit, don't forget to run 12 gauge wire and make it 20 amp. One (20 amp.) circuit can feed everything on one bathroom (only) or the receptacles (only) in two or more bathrooms. THe one circuit per bathroom is better otherwise using hair dryers in both bathrooms at the same time may trip the breaker.
Old 09-01-2010, 03:10 PM   #7
Totally screwed together
You should run a new circuit the furnace with a 12ga line.
BTW, 1974 isn't THAT old for a house!
xxPaulCPxx is offline   Reply With Quote
Old 09-01-2010, 08:06 PM   #8
not really tons of homes older I grew up in a house built in the 20's for the workers in the imperial sugar factory I am from sugar land texas.
Old 09-01-2010, 08:10 PM   #9
I am cancelling my wiring bathroom plan too much money to have permit and electritian to check new breaker box.
Old 09-01-2010, 10:15 PM   #10
You weren't going to do the work yourself?
power to "half" the house dogvila Electrical 8 07-13-2010 09:04 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
Popcorn Ceiling Repair CecszaR Painting 7 08-28-2009 03:37 AM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
