Ceiling Fan In Open Pergola - Electrical - DIY Chatroom Home Improvement Forum
Old 05-25-2008, 07:23 PM   #1
Ceiling fan in open pergola
Hello....
I just had a pergola built over my back patio. It has an 'open' roof with 2" x 8" cedar every 16" for runners. I was wondering if there was any way I could put a ceiling fan on this back patio. I figured at some point between the 16" spacing I could build a box out of cedar large enough to support the fan, stain it with water resistant stain, cover the top of the box with a sticky type roofing material they sell at lowes, and seal any areas where the wood comes together with clear silicone caulk.
Can this be done? I know I can build it and get electricity to it, but will the house burn down if it rains or if the wires are still wet from a past rain and we turn on the fan? Can the outdoor ceiling fans accomplish this, or when they say outdoor, do they mean semi-outdoor under a roofed covered patio?
Thanks for the help.
tandyt is offline   Reply With Quote
Old 05-25-2008, 09:44 PM   #2
Electrician
First off you would need to find a wet location fan, I've only seen damp location.
chris75 is offline   Reply With Quote
Old 05-25-2008, 10:52 PM   #3
Registered User
Termite's Avatar
This would definately be considered a wet location. The fan would be subject to direct spray in a rainstorm, snowstorm, or other moisture. If the entire pergola were covered, you might be able to get away with a damp location fan, depending on its protection from direct moisture.
I've never seen a wet location fan, but that doesn't mean they don't make one.
Old 05-25-2008, 11:35 PM   #4
Never heard of those types of fans. Did a quick search with the 'wet location' title and there seems to be a few on the internet. Thanks for guidance.
Old 05-26-2008, 12:35 AM   #5
Registered User
Termite's Avatar
Also, be sure that whatever wire/conduit you use is rated for the same. Can't use plain old NM romex for this.
Old 05-26-2008, 10:51 AM   #6
Rewards Points: 160
I recently bought a outdoor ceiling fan for a gazebo. The fan actually say's "wet locations". But even if the fan could run underwater how would I ever keep water out of the fan junction box and ceiling cover plate.
The fan is designed so water cannot enter the hanging pole and the blades are composite. But thats it. I would not trust it in a wet location.
Old 07-14-2008, 09:47 AM   #7
I bought a UL wet location fan, make sure it has UL wet rated stamp, you can spray it with a hose and it works fine
cchrisjj is offline   Reply With Quote
Old 07-14-2008, 09:59 AM   #8
Registered User
Termite's Avatar
Just so we all know, can you provide a manufacturer and model number?
Old 07-14-2008, 10:05 AM   #9
I will check and post tomorrow, I picked it up at Menards. It works great keeping the mosquitoes off you....the lil bastards cant land on you.
Old 07-23-2008, 11:58 AM   #10
wet location fan electrical box
Hi, I too am going to install a wet rated fan in an open patio. I found several ul rated wet ceiling fans online, and at resonable prices. icluding a wet location fan specific electrical box.
http://doitbest.com/Electrical+and+s...sku-500005.dib
hatefire is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Open beam ceiling and running wire... Alan Electrical 2 12-10-2006 09:14 PM
