Ceiling Fan Mystery - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 09:11 PM   #1
Ceiling fan mystery
I just installed a new 60" ceiling fan to a existing 5 ft or so down rod that operates by remote only. I found that I am getting 120v from the black and white wire coming down through the rod and hooked the fan up to it and no lights or fan work. I dont have a 16 ft ladder to get to the canopy but im hoping it was done right before. There is a blue wire coming down through the rod but I checked the junction box im the attic and it is not hooked up so I believe I dont need it anyhow being im getting 120v juice to my fan. Another anomaly is when i test the wires connected to fan and power its only reading 20-30v? I am at a loss as to why this is not working. The existing fan did not work but I assumed it was a burned up motor being it was getting juice or a bad remote which by the way I made triple sure my dip switches on my new fan and remote are exact. Could any 1 give me a pointer...Thanks a million
ericntx76 is offline   Reply With Quote
Old 05-21-2012, 09:46 PM   #2
My first hunch would be an open neutral! You will likely need to get a 16' ladder and check out the wiring there.
The clue is that the original fan didn't work, either!
Old 05-21-2012, 09:48 PM   #3
kevinp22's Avatar
Rewards Points: 252
posting some pics would help. is the junction box accessible from the attic - might avoid the 16 foot ladder problem
kevinp22 is offline   Reply With Quote
Old 05-21-2012, 10:01 PM   #4
I tried climbing through attic but for a big man like me its a slow and tedious experience .... So when I take measurements is it to both the black and white wire or do I use ground from metal frame ?then look at both the white and black seperatly
Old 05-21-2012, 10:03 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you can't reach the box the fan is mounted to, how are you metering the wires? There normally isn't anywhere to meter the fan wiring (black) at the fan itself without taking the whole fan apart.
Old 05-21-2012, 10:14 PM   #6
k_buz's Avatar
Is the new fan on a remote too? Is it the same one the old one was using?
Old 05-21-2012, 10:15 PM   #7
I have a 12 foot ladder and used it to get up to bottom of the down rod which all ready had the existing wiring coming through. Being that the canopy and down rod already matched color I didn't want to change them out either
Old 05-21-2012, 10:24 PM   #8
k_buz's Avatar
so you have splices in the downrod?
Old 05-21-2012, 10:52 PM   #9
" Euro " electrician
frenchelectrican's Avatar
If that the case the OP did done that way., That is a major no-no on that set up.
Merci,
Marc
Old 05-22-2012, 12:20 PM   #10
what wire in the fan did you connect to the black and white that have 120 volts? try connecting a light to the wires and see if it works.
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Ceiling Repairs and Muresco Paint: Seamless Paint Job Possible? Lovegasoline Painting 4 11-25-2009 02:06 PM
