Ceiling Fan Mouting - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 04:21 PM   #1
Question
Ceiling Fan Mouting
I have removed an old ceiling fan, probably from 1970s and wiring is too. The ceiling fan was mounted from a metal outlet/switch box. (BOX TYPE)It is mounted onto a ceiling joist. Is it okay to hang a new ceiling fan from this box???
austinbblock is offline   Reply With Quote
Old 08-02-2012, 04:40 PM   #2
No absolutely not, for many reasons.
Remove that box an install a fan rated box.
Since your existing box is probably close to the joist (I assume from your description) you will have the best luck with this type of box:
http://www.aifittings.com/products/spec-sheets/f101.pdf
Calc is offline   Reply With Quote
The Following User Says Thank You to Calc For This Useful Post:
austinbblock (08-02-2012)
Old 08-02-2012, 07:51 PM   #3
Rewards Points: 14,306
Post a picture.
Could be as simple as adding a 2 X 4 between the ceiling joist and screwing up into it through the box.
stickboy1375 (08-02-2012)
Old 08-02-2012, 08:23 PM   #4
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I agree, you dont need a ceiling fan rated box if the fan is secured to the framing.... you still need a box though.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
