Ceiling Fan Missing Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2009, 10:24 PM   #1
Rewards Points: 79
Ceiling fan missing ground wire
Picked up a ceiling fan tonight. Went to install it, and there's no ground wire on the fan, just white, black, and white/black striped. Did I just get a defective fan, or is there a way to install this without the ground?
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 08-22-2009, 08:08 AM   #2
Electrical Contractor
kbsparky's Avatar
It may not need one, if it is double-insulated.
-KB
Old 08-22-2009, 10:15 AM   #3
Civil Engineer
Rewards Points: 4,702
Normally an electrical device comes with installation instructions, including a one line electrical diagram that would clearly show how to install the ground, if a ground is required (see previous post). If you do not have the installation manual, check on the internet, it may be available from the manufacturer. In some cases, there is a ground screw on the device to attach the ground wire to (that is how my dishwasher was wired).
Old 08-22-2009, 10:41 AM   #4
Rewards Points: 79
Thanks for the info guys. There are instructions, but they're fairly generic, so I wasn't sure how to read them for my specific fan. I had just panicked when I pulled the fan out and didn't see a ground. Reread the instructions and found the part that applied to my fan, and saw the instructions for the ground screw.
Sorry for the post.
Mike
ground ? in old two wire elect system wis_remod Electrical 14 02-24-2009 11:07 AM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
Missing Common Wire? khayman218 HVAC 3 07-29-2008 05:03 PM
Ground wire turned black? n0c7 Electrical 1 07-28-2008 07:41 PM
