#1 |
ceiling fan lights don't work
I just moved into a house that has ceiling fans w/lights. one ceiling fan w/lights in the room doesn't work. I've tried changing the light bulbs themselves to no avail. The fan works but the lights don't.
Does anyone have any suggestions of what might be wrong. |
#2 |
the Musigician
Could be many things, an open wire in the light part of the fixture, overheated and burned out sockets, etc.
If it were me, I'd cut the power, open it up and look inside. There's obviously power up there, just not everywhere you need it to be. DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes! |
#3 |
Semi-Pro Electro-Geek
Just covering the obvious stuff here: does it have a pull-chain switch on it that's turned off? Usually they have a pull chain switch even if there is a separate switch on the wall to control the lights. Both switches have to be on.
#4 |
Yes pull chain is on as well. Do you think it's the switch or the ceiling fan w/lights shorting out the light bulbs?
#5 |
the Musigician
Are there separate switches on the wall for light and fan?
DM
#6 |
there are 2 pull chains 1 for the light & 1 for the fan.
#7 |
Master Electrician
Is the "dimmer" controlling both the fan and the fan light?
#8 |
the Musigician
DM
#9 |
no. just 1 switch that turns the ceiling fan lights on & off
#10 |
the Musigician
Good, we can rule out a separate switch problem then.
This seems to narrow it down to an open connection inside the fixture somewhere, most likely. DM
| The Following User Says Thank You to DangerMouse For This Useful Post: | cvtlavt (01-14-2011) |
#11 |
Master Electrician
If you have a dimmer on the wall controlling a ceiling fan then that is the problem.
#12 |
the Musigician
COULD be the problem, if there is one, ......he did not say the wall switch was a dimmer.
DM
#13 |
Dimmer on wall switch doesn't control fan only lights.
#14 |
the Musigician
uh-oh..... yes it does.... If that switch is the only one, brric is most likely correct.
DM
| Display Modes | |
| help ! lights dont work | notShai | Electrical | 15 | 05-06-2010 04:16 PM |
| Replaced some switches and outlets, now some lights don't work | DWooderson | Electrical | 3 | 02-02-2010 01:06 PM |
| Ceiling and Exterior Wall Lights | tmc8203 | Electrical | 1 | 12-05-2009 04:03 PM |
| Trying to connect ceiling lights - no lights ! | peterand | Electrical | 0 | 10-17-2009 05:55 AM |
| Work lights in basement with drop ceiling | fw2007 | Electrical | 2 | 10-20-2007 10:39 AM |
