Ceiling Fan Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2012, 10:41 AM   #1
Ceiling fan lighting
My Hampton Bay ceiling fan lights went out after working for about a year. i replace the pull switch and now get voltage to the sockets but still no light - bought 4 new bulbs. I noticed my wife had put in 60w instead of the 40w max rating for the socket and was wondering if this could have damage the lighting fixture?
Osti is offline   Reply With Quote
Old 07-08-2012, 11:54 AM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Possibly... are the lamps seating properly in the lamp holder?
Old 07-08-2012, 12:25 PM   #3
Master Electrician
cut the power to the fixture, a lot of lower end fixtures will have the tab get weak in the bottom of the socket, kill the power and bend the small tab in the bottom of the socket up a bit then give it another try. Good chance that's not the issue if all the lights stopped working at once but it's worth a try. When you say you have voltage did you use a meter or a tickle tester. Tickle testers are unreliable and can be set off by a number of things.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-08-2012, 12:27 PM   #4
E2 Electrician
I concur, if all 4 lamps stopped working at once, something is amiss...
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Installing recessed lighting in a new drop ceiling rwood@weg.net Electrical 2 11-30-2011 02:54 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 04:46 AM
