Old 08-17-2012, 04:45 PM   #1
ceiling fan and light wiring
The box in the ceiling has a red, a black, a white, and a ground wire. All the whites and the grounds in the switch box are wired together. The black is not contected to anything. When I turn the switch on with the red wire attached, every wire (including the red) reads hot with a KLEIN Tools NCVT-1 voltage tester at the ceiling box. When I turn the switch off, all the wires are dead.
philwitty is offline   Reply With Quote
Old 08-17-2012, 04:59 PM   #2
E2 Electrician
stickboy1375's Avatar
What you are reading is capacitive coupling between energized circuits and non energized, non connected adjacent wiring.
The Black wire is really not energized.
