Old 03-18-2006, 12:49 PM   #1
ceiling fan light switch replacemnet
I bought celing light switch & would like step by step instructions in case the instructions enclosed are hard to understand.
thomasr1950 is offline   Reply With Quote
Old 03-18-2006, 03:42 PM   #2
It's difficult giving step-by-step instructions without knowing exactly what you have now and what the new switch is.
However, generally, here are the steps:
1) TURN OFF THE BREAKER FOR THE SWITCH
2) Remove the 2 screws on the plate.
3) Test the wires for electricity - make sure there is none.
4) remove the 2 screws holding the switch into the box.
5) You could have two issues here:
a) If the wires are screwed to the side of the switch, unscrew those wires and replace with your new switch in opposite order.
b) Sometimes the wires are inserted into the back of the switch. If this is the case, cut the wires from the old switch, strip the appropriate amount of insulation off the wire and replace with your new switch.
leboyd is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 04:36 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
Ceiling Fan Light Switch Replacement leanthinkin Electrical 2 08-22-2006 01:10 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 07:11 PM
