Old 08-20-2006, 01:42 PM   #1
Question
Ceiling Fan Light Switch Replacement
Help! I need to replace the pull chain for the light in a ceiling fan. I purchased a new one, but how to I get the socket out of the fan so that I can replace the wiring into the top of it..... does someone have directions, please......?
leanthinkin is offline   Reply With Quote
Old 08-20-2006, 02:09 PM   #2
There should be three or four screws that hold the whole canope in from the sides of the light kit on the fixture. Make sure power is off. Use a pencil or some tape to mark which way the kit is aligned. Remove the screws from the side of the light kit and the whole thing should drop down.
You may find a quick connect plug here so that you can take the light kit down and work on the pull chain on a table or work bench. If not there may be wirenuts just be sure to make a note of how they are wired.
jwhite is offline   Reply With Quote
Old 08-22-2006, 01:10 PM   #3
hi,
just a quick note, i think is worth mentiong. make sure the switch u install for the light/lights on the fan is rated at the same amps. all the pull chain switches look very much alike on the outside. i bought a light switch for my ceiling fan, and didnt realize it was 3amp, til i got it home and took it out of the package! i neeeded a 6amp switch! thats my mistake for not looking when i bought it, but, it happens, so LOOK before u buy!
bob
bobo is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Installing a ceiling fan with a light switch. Unregistered Electrical 9 08-23-2011 04:36 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 09:40 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
ceiling fan light switch replacemnet thomasr1950 Electrical 1 03-18-2006 03:42 PM
