Ceiling Fan Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2011, 10:05 AM   #1
ceiling fan light problem
Hi,
New to the board so would appreciate any help on this issue. We have had a Hampton Bay ceiling fan for a number of years. Replaced the circuline bulb a few years ago and had no problem. Recently the light dimmed and then shut off so I picked up another 9" 30 watt bulb (matching previous and description on the fan). When I reinstalled (tried prongs both up and down), the light will no longer go on. Tried buying another type of bulb and it wont work either. Fan works fine though. Any thoughts?
darren260 is offline   Reply With Quote
Old 03-02-2011, 10:14 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Ballast probably needs to be replaced.
Kyle
Old 03-02-2011, 10:17 AM   #3
Thanks Kyle. That was my original thought but wasn't sure if thats an easy procedure. Tried to see how to remove the current one, and didn't seem to budge.
Old 03-03-2011, 06:05 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
Hmmm...double sided tape or glued down?
Kyle
Old 03-03-2011, 06:35 AM   #5
the Musigician
DangerMouse's Avatar
I've seen them pop-riveted down too...
DM
Old 03-03-2011, 09:13 AM   #6
Thanks. Worked with it more and found it had a pop rivet attachment. Easily removed the old ballast and will be looking to find a replacement. Appears they are still selling them online. Hopefully this will be the solution.
Old 03-03-2011, 10:30 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
You might check your local hardware, big box stores or electrical supply houses. Good chance you can find one locally.
Kyle
Old 03-04-2011, 09:13 AM   #8
Since its a Hampton Bay fan, and to my knowledge only Home Depot sells those, I checked with them. Said they don't sell most of the replacement parts in the store. I think I found it online. Will be here in about a week and then I should know if its the ballast or not.
Old 03-04-2011, 09:17 AM   #9
the Musigician
Considering all the symptoms, I think you found the culprit.
I'd bet money it'll be fine.
DM
Ceiling Fan Circuit Problem G_S_DB Electrical 1 08-25-2010 07:24 PM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 01:12 PM
Problem Installing Track Light MrBill_DIY Electrical 5 11-12-2008 10:35 PM
Ceiling Light problem Smiler Electrical 4 05-26-2008 09:40 AM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
