Ceiling Fan/Light Out - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2011, 03:12 AM   #1
Rewards Points: 512
The ceiling fan w/ light has gone out. Both fan and light are not working, and there's voltage to the switch. Haven't checked yet at the fan box. Is there a way to eliminate the fan motor and hook up just the light? We're not ready to buy a new fan, and really don't need it right now, but we do need the light.
There's a 4.75F capacitor in the light housing that I suspect is causing the fan to not work, but I'm not sure if it would also cause the light to not get voltage (which it isn't at the light socket)
Old 05-31-2011, 06:24 AM   #2
Most fans that I have installed have separate connections for light and fan. One could wire the light and leave the fan unhooked without any problem.
oberkc is offline   Reply With Quote
Old 05-31-2011, 01:43 PM   #3
Rewards Points: 512
Well, I'm assuming that there's a 3-wire cable to the ceiling fan (B,W,R) because I've got a black and red on the wall switch. But apparently, there must be a rewiring situation required in the light kit housing in order to make it work light only... hmm
Old 05-31-2011, 08:48 PM   #4
Well, I'm assuming that there's a 3-wire cable to the ceiling fan (B,W,R) because I've got a black and red on the [COLOR=blue !important][COLOR=blue !important]wall [COLOR=blue !important]switch[/COLOR][/COLOR][/COLOR]. But apparently, there must be a rewiring situation required in the light kit housing in order to make it work light only... hmm
it sounds to me as if you need to open up your relevant boxes to see how things are wired. I have heard nothing in your posts that eliminate the possibility that the fan has separate power for fan and light.
Old 06-01-2011, 12:19 AM   #5
Rewards Points: 512
This has been fixed. The neutral came off at the fixture. There is no separate wiring for fan & light: Blue and Black combined.
Old 06-01-2011, 05:45 AM   #6
What has been fixed/
My assumption is that blue is light and black is fan. I assume, also, that there is a white wire for neutral.
Confirm which of the two wires (blue or black) powers the light. Leave the other one disconnected.
The Following User Says Thank You to oberkc For This Useful Post:
sirsparksalot (06-01-2011)
Old 06-01-2011, 02:00 PM   #7
Rewards Points: 512
oberkc, Everything is fine now. Thanks for the comments.
Ceiling fan/light combo malfunctioning jkrodger Electrical 17 12-03-2015 08:19 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 07:20 PM
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-18-2011 11:44 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
