Old 09-28-2012, 10:23 AM   #1
Question
Ceiling fan light no longer working?
I'm in a new home with 5 Hunter ceiling fans. The fans were all installed within the last year. My kitchen ceiling fan light bulbs blew last night when I turned the switch on. I replaced the bulbs, but they will not work. I checked the bulbs in other fixtures and they are good bulbs. The ceiling fan is still working? I have checked what seems to logical and apparant but can't locate the problem. Is Hunter having an issue?
Elise Nguyen is offline   Reply With Quote
Old 09-28-2012, 12:19 PM   #2
Some Hunter ceiling fans have a limiter installed from manufacturer, when you replaced the light bulb(s) did you get the same wattage?
If you replaced with larger watt bulb they wont work.
Most I have seen were 40 watt bulbs.
Gac66610 is offline   Reply With Quote
Old 09-28-2012, 01:14 PM   #3
The wattage limiter is supposed to allow the larger bulbs to function. It just restricts the bulbs to 190 watts total. Or that is how it is supposed to work.
It could be the source of your problem. I'd give Hunter a call on it.
Oso954 is offline   Reply With Quote
Old 09-28-2012, 01:54 PM   #4
is it just the bulb or bulb *and* fan that are not working?
allthumbsdiy is offline   Reply With Quote
Old 09-28-2012, 02:50 PM   #5
The fan is still working fine. Just the lights are not working.
Old 09-28-2012, 08:04 PM   #6
The wattage limiter could have been damaged when the lamp blew !
You might have to replace it !
dmxtothemax is offline   Reply With Quote
Old 09-28-2012, 09:23 PM   #7
According to Hunter's FAQ, you probably cannot replace the limiter alone as they do not sell individual components.
You should give them a call to see if you can get warranty parts. I have three Hunter ceiling fans and they have been fantastic about resolving issues.
Good luck
Old 09-29-2012, 12:11 PM   #8
Thumbs up
Thanks to all of you for your responses. I'll contact Hunter. Thanks.
Double light switch not working correctly Dame147 Electrical 0 10-11-2011 01:03 PM
Light fixture in ceiling fan won't work. Tested DIYself Electrical 7 11-28-2010 12:52 PM
Normal light fixtures with suspended ceiling? Scott99999 Electrical 9 09-02-2010 05:44 PM
Tying in wiring to existing ceiling light samson115 Electrical 3 11-22-2009 01:12 PM
Cannot get new kitchen ceiling light to go off dbev07 Electrical 15 11-18-2008 01:27 PM
