Ceiling Fan Light Doesnt Work - Electrical - DIY Chatroom Home Improvement Forum
Old 04-07-2013, 06:48 PM   #1
Ceiling fan light doesnt work
Hi everyone, I have a harbor breeze fan from Lowes and all of a sudden the light dont turn on. I changed the light bulbs and it still would not work. I disconnected the light fixture, took it down to Lowes to see if they could help. The guy tested the switch and it did not work. Since they were sold out of switches he clipped off the switch to test it again and it did work. They gave me a new light fixture and said to do a quick reconnect and if that did not work it would be the limiter. Of course when I got home it did not work. What do I do next.
Sorry for long details.
verpear is offline   Reply With Quote
Old 04-07-2013, 11:33 PM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
We need more info to help you out. Also some pictures of the wiring & connections couldn't hurt. On your new ceiling fan, is it just the lights that won't work or does the fan not spin either?
fetzer85 is offline   Reply With Quote
Old 04-08-2013, 12:41 AM   #3
Rewards Points: 512
Did you install the fan/light yourself?
At any rate, take the fan down and check the wiring in the ceiling. A loose wire sounds like the culprit.
Old 04-08-2013, 08:42 AM   #4
Rewards Points: 14,312
Check where the blue wire connects to the black wires up inside the mounting box at the ceiling.
You took it to a box store to check it.
Go buy a volt OHM meter.
sirsparksalot (04-08-2013)
Old 04-08-2013, 06:15 PM   #5
It was professional installed by an electrician. Thanks for the reply I will check it out.
Old 04-08-2013, 11:08 PM   #6
Rewards Points: 512
Means nothing. Pros get sidetracked too, sometimes.
Let us know the results?
Old 04-09-2013, 07:44 AM   #7
I have a meter already, would I need to check all the wires?
Tags
fan , light , switch
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Hunter Ceiling Fan and Harbor Breeze Light Kit Rafterman414 Electrical 3 01-06-2013 07:46 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Help- cant get a new ceiling fan light to work boddabing Electrical 6 08-26-2010 05:24 PM
can't get new light fixture to work carolcwilson Electrical 24 08-12-2008 12:52 PM
