Ceiling Fan Light Comco Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 04:34 AM   #1
Ceiling fan light combination wiring
I am thinking about putting a ceiling fan in my bedroom. It's easy access to the ceiling box. I know I have to put in a safety box. Do I use 14/3 or 12/3 for the switch wire.
Dilligaf77 is offline   Reply With Quote
Old 03-24-2008, 05:25 AM   #2
When is fishing season?
CowboyAndy's Avatar
What size wire will depend on what size the rest of the circuit is and what size breaker there is for it.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-24-2008, 05:48 AM   #3
The wire feeding the light is 12/3. The breaker is 20 amp.
Old 03-24-2008, 06:22 AM   #4
CowboyAndy's Avatar
Then use 12/3 wire.
MY HOUSE OWNS ME!
Old 03-24-2008, 10:03 AM   #5
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I am understanding this as you are replacing an existing light with a ceiling fan. Please go into more detail on the purpose of the 12/3 feeding the existing light. Is it the incoming power cable or is it coming from the light switch? Is the existing light switch 3 way or single pole. You may or may not need 12/3 to complete the wiring, you may not need to do anything different other than install a fan box. I am assuming the fan has a light dome since you will be replacing a light. Do you want independent control of the light and fan from 2 switches on the wall ? Or do you want one switch on the wall controlling the light and a pull chain controlling the fan? Is the fan going to have a remote? You may not need a 12/3 G and would not have to run it...especially if that is going to be hard to do. You may be able to use the existing wiring.
If your running to a new switch location then by all means run a 12/3 whether you use both hots or not.
Old 03-25-2008, 05:23 AM   #6
Fan Light combo wiring
OK this is the final deal. My house was built in 1906. MY friend told me it is a balloon frame house, and you can actually shine a light in the cellar, and see it from in the attic in places. The wiring is BX with no ground. There are 7 lights up stairs. He said I should pull a wire up to the attic, and put all the lights on one feed. I would love to put ceiling fans in the 3 bedrooms but that sounds like to much stuff to put on one wire. There are switches, and none of the wire is nailed down. He said we can use old work boxes and everything will be safe. He is going to help me but I think that is to many lights for one wire #12. Every thing is wide open and easy to get to. The house has a 100 amp service installed in about 1970 and is all breakers. The kitchen has new wire, and GFI breakers.( MY friend is a drinker, and some times I don't believe what he says.) I would like 2 switches in one box, one for light and, one for the fan. I do know that requires 3 wires of some size. My friend is in construction and works with electricians all of the time. He said it is a 12 pack job/ $200 materials.
Old 03-25-2008, 05:44 AM   #7
CowboyAndy's Avatar
Is it 7 fan/lights, or 7 lights with 1 or 2 fans?
To see if it is acceptable or not to put all that stuff on one circuit take the wattage of all the lights (not what you have for a bulb - but the actual max wattage rating on the fixture) and for the fans. Depending on what size wire is used for the new circuit will determine how many you should put on it. *IF* it is mostly lights, with 1 or 2 fans then 14AWG should suffice. If it is going to be 7 ceiling fans, then 12AWG will be the way to go.
MY HOUSE OWNS ME!
Old 03-25-2008, 06:22 AM   #8
3 fan light combos, and 4 closet lights.
Old 03-25-2008, 06:35 AM   #9
CowboyAndy's Avatar
You will definatly be okay with 1 circuit. I would go with 12/2 for the wiring. What your friend told you is a fairly reasonable task. My house is the same way, where you can see from attic to basement. For a 12 pack and $200, I would say go for it as long as you understand this:
-Make sure your friend can legally work on your house (does your state require an electrician to be licensed or work under a licensed person?)
-This job will most likely require a permit and inspection.
-If these are going to a bedroom(s) then you may be required to protect them with an arc-fault circuit breaker - check with your local AJH.
Good luck!
MY HOUSE OWNS ME!
Old 03-25-2008, 06:41 AM   #10
License
He is going to do it under a master electrician that is also an inspector. The permit will cost $68.00. I ain't worried about the State, I'm worried about my home owners Insurance.( Same thing basically, same rules different pocket)
Old 03-25-2008, 06:51 AM   #11
CowboyAndy's Avatar
Well, sounds like all your ducks are in a row.
If he's going to be working in the attic, make sure to buy him premium beer...
MY HOUSE OWNS ME!
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
