Ceiling Fan Light Bulbs? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2008, 04:45 PM   #1
Rewards Points: 666
I have just installed a Hunter ceiling fan in my home. The light kit calls for two chandelier type light bulbs. These two bulbs do not put off much light. Does anyone have a suggestion on better types of bulbs to use that will put off more light and be as much or more energy efficient. Thanks!
kennykenny is offline   Reply With Quote
Old 07-28-2008, 05:31 PM   #2
Whatamess
What watts are you using. Will most likely handle 60 watt.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 07-28-2008, 06:17 PM   #3
Rewards Points: 666
They are 60 watts bulbs. It's just that they don't seem to put off enough light for the rooms needs.
Old 07-28-2008, 06:24 PM   #4
Whatamess
Two things you may want to get a different light kit with more bulbs. Also make sure if it is remote control operated the lights are not dimmed.
Old 07-28-2008, 06:27 PM   #5
Rewards Points: 666
The fan does have to be used with remote. Do you know how to verify that it is not dimmed and if it is how to make the dimmer brighter? Thanks for your help!
Old 07-28-2008, 06:47 PM   #6
Electrician
I get this complaint quite a bit, ever since ceiling fans went "GREEN" which means they joined forces with energy star, your not really going to like light kits with ceiling fans anymore.
chris75 is offline   Reply With Quote
Old 07-29-2008, 06:17 AM   #7
Whatamess
Most remotes you just hold the light switch down and it will dim or brighten. If that does not work find the owners manual.
Old 07-29-2008, 07:16 AM   #8
naturelimit
The 60 watt bulb is enough for normal house work but for other works it wont suit. Better check for the connection made and the electrical work.
Saimaxx - Wholesalers providing building, building and construction industry, suppliers of building materials, specialist distribution centre
naturelimit is offline   Reply With Quote
Connecting a Ceiling fan to a Light Switch AceAvenue Electrical 6 06-03-2008 03:06 PM
losse light bulbs and dim slow ceiling fan vmnorton Electrical 2 05-04-2008 06:41 PM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
ANOTHER ceiling fan light fixture doesn't work bandguy Electrical 8 06-13-2007 08:40 AM
