Ceiling Fan Light Blown - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 03:17 PM   #1
I was trying to identify which breakers covered which rooms. After completing this task, both lights in my Twin Ceiling Fan were blown. Bought new 75watt screw-in halogen bulbs and replaced them. The lights still won't come on. The fan works fine. HELP PLEASE!!
Ceiling Fan Light Blown-ceiling-fan-004.jpg   Ceiling Fan Light Blown-ceiling-fan-005.jpg
bertjames is offline   Reply With Quote
Old 03-20-2011, 05:58 PM   #2
" Euro " electrician
frenchelectrican's Avatar
I know you say fan work fine but not the lights so therefore do you have dimmer switch for the lights if so replace the dimmer { test with simple toggle switch to rule it out } if toggle switch part work with light then the dimmer is shot.
When the bulb burn out some case it can actaully wreck the dimmer swtich I have see that quite few time. { the current surge will kill them when the bulb start to arc aka burn out }
Merci.
Marc
Old 03-20-2011, 06:05 PM   #3
No dimmer switch for the lights. There is a remote control and no pull cords. I have the unit hooked up to two light switches, then use the remote for the fan option.
Old 03-20-2011, 06:15 PM   #4
Ok as you say no dimmer on this unit at all and the remote do not have dimmer feature hook up then you will have to check the connection at the centre dome { bottom part } to make sure the connections are tight some case you may find them get loosen up.
Once a while you may find a wattage limter device in there it may look like little black box IIRC if so try bypass it that will useally take care of that and double check the reciver remote unit on way the top where the remote controller located to double check if the lights are hooked up or not.
Hope that help you with it.
Merci.
Marc
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Trying to install a new ceiling light in an old house Yikes Electrical 2 07-25-2010 11:49 PM
Light fixture in a drop ceiling? kosherdill Electrical 1 03-01-2009 12:23 PM
Recessed Light on Curved Ceiling? mfleming Electrical 2 10-31-2008 06:53 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
