Ceiling Fan/Light - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 06:59 PM   #1
Ceiling Fan/Light
In 3 upstairs rooms we have switches by the door that control the bottom half of an outlet. All 3 rooms have ceiling fans with lights already installed in the rooms. I would like to have the lights, at least if not the fan as well, controlled by the switch instead of the outlet.
In the outlet controlled by the switch I have 1 romex 3 cable plus gound and 1 romex 2 cable plus ground.
In the switch I have the same thing as the outlet. 1 romex 3 and 1 romex 2.
Ceiling fan is wired to be constant hot and controlled by the pull chains.
Any help would be appreciated.
mtjtucker is offline   Reply With Quote
Old 10-22-2010, 07:33 PM   #2
joed's Avatar
Rewards Points: 12,334
You need to determine if the fan feed is in the switch. First determine if they are on the same breaker. Does turning off the breaker for the receptacle also turn off the fan? If it does then disconnect the black from the two wire cable in the switch box and see if the fan goes off.
installing ceiling fan/light fixture. raineydr Electrical 5 03-26-2010 11:11 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Adding a ceiling fan/light macblair Electrical 5 07-08-2009 04:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
