-   -   Ceiling fan with light - 2 switches, one for fan, one for light (http://www.diychatroom.com/f18/ceiling-fan-light-2-switches-one-fan-one-light-18796/)
vendejp 03-21-2008 03:17 PM
Ive searched up and down here and havent found exactly what im looking for.
I have a ceiling fan with lights. I want the fan on a switch and the lights on a dimmer.
The fan has:
1 black (hot)
1 white (shared)
1 blue (hot for lights)
it also has a remote reciver, but im just cutting that out of the picture.
my understanding is that i can (grounds are a given for all these, so im not going to put them in):
have two 12-2 w/ground lines going to the fan.
one will have:
black to black (hot)
white to shared white
the other will have:
black to blue (hot)
switches will go in each hot line
sound right?
thanks in advance
CowboyAndy 03-21-2008 04:31 PM
Yes, sounds like you are pretty prepard for this.
Is it already wired? If not, I would consider using 12/3. It would be a bit of a time saver, only having to run 1 cable instead of 2.
And remember, make sure there is a ground to each switch, and the fan BOX (should be metal, if it is plastic than there is a VERY good chance it is NOT fan rated).
Good luck!
vendejp 03-21-2008 05:14 PM
thanks cowboy, yes, its a metal fan rated box with the supports. i forgot to mention the 12/3... i just dont have any but have a bunch of 12/2 which i already ran. you are right, it would have been easier, but i didnt want to buy any.
thanks for the reply!
220/221 03-21-2008 05:33 PM
You dont need to hook the extra white up. You can just leave it capped in the box.
