Ceiling Fan Lamp Issues, Could Use Some Help/advise - Electrical - DIY Chatroom Home Improvement Forum
Old 07-19-2011, 02:25 PM   #1
Ceiling fan lamp issues, could use some help/advise
About two months ago I installed a new ceiling fan complete with new box and wiring. It has a built in two bulb lamp and I installed a Hampton Bay remote control. This morning leaving for work, around 5:45 am, I looked up and noticed both bulbs doing a strobe effect flashing, very dim, but was there and can only be seen in really dark situations. Both the fan and lamps were off. Now I think I would of noticed this if it started right at installation, but not sure. The bulbs are both newer fluorescent style bulbs.
Any ideas?? Should I use an Incandescent bulb?? Should I be worried that something may be shorting out and be warned of fire?? Thanks in advance!
D-rock is offline   Reply With Quote
Old 07-19-2011, 02:56 PM   #2
Licensed Pro
Switch to incandescent bulbs. CFLs require a special dimmer, which the remote probably is not.
Old 07-20-2011, 12:40 AM   #3
Thadius856's Avatar
Rewards Points: 504
I thought the chances were that most CFLs labeled "dimmable" could be used with most dimmers designed for incandescents.
Can you send a link? I'd like to learn more.
Thadius856 is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-18-2011 11:44 PM
Dark color & downlighting to reduce ugly ceiling in downtown loft bathroom? fredonian Painting 3 08-17-2009 09:20 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
want to make ceiling light fixture into plug-in lamp Cahill_Main Electrical 8 01-31-2008 03:55 PM
