Ceiling Fan Keeps Tripping Breaker .... Help - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 09:09 AM   #16
Licensed electrician
Rewards Points: 1,268
The latest codes call for AFCI protection pretty much for any area that is not GFI protected.
Old 07-30-2012, 11:01 PM   #17
Rewards Points: 398
I would check for a loose wire somewhere and test with two toggle switches first then move to the combo if you are unsure.
Fan:
black to black
White to white
Blue to red
Copper to copper
Switch one:
Live black to switch
Fan black to switch
Fan White to live white
Fan Copper to switch green screw then to live copper
Switch two:
Jumper from switch 1 live side to switch 2
Fan red to switch
Fan white to live white (3 total now)
fan copper to switch green screw then to live copper (3 total now)
With this configuration one switch should operate the fan and the other should work the light each independently. If this works without tripping the breaker report back and we can walk you through the combo wiring.
adgjqetuo is offline   Reply With Quote
Old 07-30-2012, 11:13 PM   #18
Master Electrician
The grounds can't go to the switch and then to the box. They all need to be wirenutted with pigtails to the switch grounds.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-31-2012, 12:14 AM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I'm not certain but I believe there are some solid state fan controls that you cannot use on a circuit with afci breaker, gfci breaker or load side of gfci receptacle.
Do the installation instructions say anything about restrictions for this fan control ??
Old 07-31-2012, 06:44 AM   #20
Rewards Points: 398
I know that's best practice for permenant installation, I was just trying to hook it up temporarily to see if we can at least get it running without tripping the breaker.
The combo switches typically have a green wire to them which can be connected directly to the main ground for permenant installation.
Old 07-31-2012, 07:15 AM   #21
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
So, you have determined that with the fan down, the breaker holds.
I would do what Jim suggested earlier, take the fan/speed control off, install two single pole switches to test if the fan itself is tripping the AFCI.
If it is the fan/speed control, you could look for remote kits you can wire into the fan to achieve the same result as your in-wall control.
breaker keeps tripping RMCarner Electrical 29 07-22-2012 10:53 AM
Breaker tripping without load after heavy rain mikemcd Electrical 11 09-12-2011 03:43 PM
ARC Fault breaker tripping zevo Electrical 12 09-04-2011 03:11 PM
Intermittent circuit, breaker not tripping lucabrasi Electrical 5 03-14-2010 08:03 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 05:13 PM
