Ceiling Fan Keeps Tripping Breaker .... Help - Electrical - DIY Chatroom Home Improvement Forum
Old 07-27-2012, 12:45 PM   #1
ceiling fan keeps tripping breaker .... help
Ok first of all I wanted to say what a great site this is!
This is the first time I couldnt find an answer that got me through my current jam so I signed up
I am replacing a ceiling fan that never worked since we purchased our home. It is a fan / light combo and the wall switch is a Lutron Dual Slide-to-off Fan Control / Dimmer single pole - quiet 3-speed, Ceiling fan / Incandescent/Halogen light, 120 V / 1.5 A / 300 W
Long story short not matter how I wire it in the breaker trips -> here is what I have
at the wall switch I have the incoming wire with black - white - copper (ground)
I have the second wire going to the fan which is black - white - red - copper (ground)
my switch is a lutron S2-LFSQ -> with a green - yellow - black and red wire
per the instructions
green is ground
black is connected to the black hot from the breaker panel (incoming wire)
yellow wire powers the fan
red connects the light
I feel like I have tride a million configurations of these wires all to no avail. I also tried to wire just the fan and light with no luck
right now the white wires are connected in the wall box
black wire from the switch is connected to the black wire coming in the wall box (to breaker panel)
yellow is connected to black wire going to fan
red is capped
HELP?!?!?! I've fiddled with this thing for 3 days and am going a little CRAZY
jdl508 is offline   Reply With Quote
Old 07-27-2012, 12:51 PM   #2
Licensed electrician
Rewards Points: 1,242
Does the breaker trip regardless of whether you try to turn on the fan or the light? Does the breaker stay on with no switch installed?
Old 07-27-2012, 01:08 PM   #3
The breaker only trips with the switch powered on While in an off state the breaker is fine
Old 07-27-2012, 01:32 PM   #4
Does the breaker trip on the fan or light function? Can you replace the switch with 2 toggle switches for testing?
Have you checked the canopy connections?
Old 07-27-2012, 02:01 PM   #5
Master Electrician
Yup need to know what goes where at the light. Assuming the threewire goes to the fan for individual control.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-27-2012, 02:35 PM   #6
I can go get a toggle switch and try that
I'm out at the moment but unfortunately I only tried the fan to trip the breaker will follow up on that going to lowes now to get the toggle switch
Yes the 3 wire ( red black white) goes to the fan and the 2 wire comes in from a switch in the series
Old 07-27-2012, 04:08 PM   #7
Master Electrician
You have a short. When you flip the switch its shorting out. Either the fans wired wrong or somethings not right load side of the switch. Id pull the fan down and recheck connections.
The Following User Says Thank You to andrew79 For This Useful Post:
Evstarr (07-27-2012)
Old 07-27-2012, 08:57 PM   #8
Electrical Contractor
kbsparky's Avatar
Are you tripping an AFCI breaker?
-KB
Old 07-28-2012, 08:57 AM   #9
It is a type afci / chap made by eaton
I tried to call a few electricians a few days ago but no call back I guess no one is interested in installing something so small so I'm on my own
Old 07-28-2012, 08:59 AM   #10
Can anyone give me an idea of how this thing should be wired? Is the 2 slider single pole switch ok? Anyone near Philly that wants some side work lol
Old 07-28-2012, 11:19 AM   #11
kbsparky's Avatar
OK, now we are getting somewhere.
You most likely have a ground fault between the switch and the fan.
Remove the connections at the fan, and cap the wires coming from your ceiling box. TEST the switch again: Does the breaker still trip?
If so, you have a pinched wire in your wiring.
If not, then something is grounded in your fan. You may have to check for proper connections, even internally in the fan control cup if necessary.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
andrew79 (07-28-2012)
Old 07-29-2012, 02:29 PM   #12
ok so i terminated all the connections from the ceiling with wire nuts and viola the breaker did not trip - so this means......
I have something wired wrong at the fan?
Old 07-29-2012, 02:44 PM   #13
Master Electrician
Yup or was just lose.
Old 07-29-2012, 03:55 PM   #14
ok I am sure I am mis wiring something here but I am really starting to feel clueless
for goodness sakes there are only so many combinations , I have even tried a different lutron switch that has a single slider and only operates the fan (sfsq-f)
if someone could tell me what they think should be connected to what -> I will try and number all connections
at the wall switch I have the incoming wire with black(1) - white(2) - copper(3) (ground)
I have the second wire going to the fan which is black(4) - white(5) - red(6) - copper(7) (ground)
my switch is a lutron S2-LFSQ -> with a green(1L) - yellow(2L) - black(3L) and red(4L) wire
The fan has the following wires -> green (1F) red (2F) black (3F) blue (4F) white (5F)
so here is the schematic
1 -> 3L
2 -> 5 ->5F
3 -> 1L -> 7 -> 1F
2L -> 4 -> 3F (power for fan)
4L -> 4F (power for the light kit)
sorry for sounding so desperate LOL
Old 07-30-2012, 08:07 AM   #15
i think I have come to the conclusion that I need to swap out the afci breaker for a traditional style breaker
This breaker serves the living room / dining room any reason I need an afci on that circuit?
breaker keeps tripping RMCarner Electrical 29 07-22-2012 10:53 AM
Breaker tripping without load after heavy rain mikemcd Electrical 11 09-12-2011 03:43 PM
ARC Fault breaker tripping zevo Electrical 12 09-04-2011 03:11 PM
Intermittent circuit, breaker not tripping lucabrasi Electrical 5 03-14-2010 08:03 PM
HW tank breaker tripping arichard21 Electrical 6 10-31-2007 05:13 PM
