Ceiling Fan Junction Box W/o Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 07:29 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I've done houses with all radio ra 2, I installed all the switches in the basement, they use there iPhones to control the lighting... It's all legit.
Old 10-31-2012, 07:33 PM   #17
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I won't argue, inspectors here won't go for it, and I highly doubt that will fly with other areas. It defeats the entire purpose of the requirement if the switched outlet if the switch isn't required to be in or adjacent to the room it services.
Old 10-31-2012, 07:37 PM   #18
E2 Electrician
I won't argue, but the switch isn't required in the room or near it. And any inspector is abusing his power if he requires anything more than code. Sorry you don't share the same view, also... If anyone actually wired a house to bare minimum code wouldn't be in business very long, just saying.
Old 10-31-2012, 10:00 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Just my 2 cents. You are required to have a switched light via receptacle or a swtched ceiling light. No inspector is going to allow you to switch a freakin bedroom light or any room light in a finished area from a circuit breaker in a panel. Your kidding yourself if you think that is going to happen.
In this case I think what they mean by "no switch" is just power to the fixture and the fan and light dome switched by pull chains.
FWIW I'm always interested in the intent of code language. However the OP is talking about the options for switching his room lighting... ceiling fan or whatever as offered by the builder. I really don't now why we are going off on the fact that code language would allow you to switch the light from the circuit breaker panel. No one in new constructuion would wire that way ... Your going to lose your appeal to the ahj and I doubt that Stickboy or anyone hear that has wired residential has ever done this. BUT I'm forced to agree the NEC doesn't say that the switch must be in the same room ..... An inspector would probably look at me and say does that breaker look like a wall switch to you .....
how to install ceiling fan and light/fan control switch on 3-way DIYguy2000 Electrical 11 07-24-2012 06:15 AM
Wiring a Ceiling Fan to a Switch that also Controlls Hot Switch timsarah Electrical 6 03-30-2010 08:14 AM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 12:09 AM
Wiring Ceiling Box to Switch graceandhayes Electrical 1 10-23-2006 05:02 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
