Ceiling Fan Issue - Steep Roof - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2010, 11:01 AM   #1
Rewards Points: 3,130
Ceiling fan issue - steep roof
I have a log house with a 12/12 roof. The electrician hanging my fixtures and such says he can't install the ceiling fans because the roof is too steep. It isn't that the blades would hit the ceiling, but that the down rod won't swivel enough to hang vertically. Surely there's a way to fix this??
Old 10-01-2010, 01:58 PM   #2
Licensed electrician
Rewards Points: 1,608
Go to aifittings.com and look for the FB450 and the FB900. Both are made for sloped ceilings.
You could also install a piece of wood and use a regualr fan rated box.
Old 10-01-2010, 02:18 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
time for an electrician with vision.
Hey, I'm not working right now.
Old 10-01-2010, 11:41 PM   #4
" Euro " electrician
frenchelectrican's Avatar
I have work with 12/12 pitch before and the item what Jim mention I used alot and make sure you get the ceiling fan with much longer downrod the length of the rod it will depending on the size of fan itself and what type of mounting it have.
I know few big box store will stock pretty long downrods IIRC the longest I did see in big box store is 5 footer and they are not too bad but some case longer { I did have one ceiling fan with 8 foot downrod }
Merci.
Marc
Old 10-04-2010, 01:37 PM   #5
Thanks for the replies. Turns out there's an easy solution for this. Hunter makes a vaulted ceiling mount that will handle up to a 12/12 pitch.
supporting ceiling while reworking roof KarlJay Roofing/Siding 1 09-30-2010 09:47 PM
Ceiling fan issue jho Electrical 2 07-06-2010 10:58 AM
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
Building Cathedral ceiling roof truss cdc1505 Building & Construction 3 05-06-2009 04:38 PM
Cathedral Ceiling Insulation/Reflective Roof Coatings badnewsbair Roofing/Siding 3 06-18-2008 04:31 PM
