Ceiling Fan Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2010, 10:49 AM   #1
jho
jho's Avatar
Ceiling fan issue
This isn't so much an electrical issue as it is an installation, but figured a lot of you guys have installed more than one ceiling fan before. I've done quite a few myself, but never had to repair any. The one of concern to me is in my office. It's an older fan with three light pendants, and when on medium or high speeds, the thing wobbles so bad that it almost seems like it's going to pop right off the ceiling. I'm sure it's a balance issue.
My question: Is there anything I can do to fix this, or would I be better off replacing the whole thing? TIA
jho is offline   Reply With Quote
Old 07-06-2010, 10:52 AM   #2
Licensed electrician
Rewards Points: 1,494
Have you checked to see if all the mounting connections are secure and all the fan blades are tight?
Old 07-06-2010, 10:58 AM   #3
jho
jho's Avatar
You the man, Jim! Just checked the tightness of the screws on the blades, and sure enough, one of them was loose. Just tightened them up and the thing runs almost like brand new. Still a little wobble, but I can deal with it. Thanks a lot!
Height of a ceiling fan with a trey ceiling? Bacardi 151 Electrical 7 09-08-2010 10:55 AM
Ceiling paint sheen options... J Barr Painting 4 05-30-2010 12:22 PM
Is my room pre-wired for a ceiling fan? cfrederick02 Electrical 1 04-02-2009 01:08 PM
Ceilin fan issue diywic Electrical 13 08-22-2008 07:29 PM
ceiling fan dimmer switch issue irich Electrical 4 02-10-2008 10:23 PM
