Ceiling Fan Installation On Vinyl Soffit? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2011, 10:18 PM   #1
Ceiling fan installation on vinyl soffit?
Hi to all-
This is my first post here, and it's a little hard to say where it should actually go. I guess "electrical" is as good as any...
I started putting up vinyl soffit all around my house and that has gone so well that we decided to do the front porch ceiling and under the carport the same way.
Question is that there are four ceiling fans and I'm not quite sure how to work the vinyl around them. I picked up a few of those square two-piece mounting plates for lights, etc. but I'm not comfortable mounting fans on something like that. Too risky.
I've thought about using box extenders that would bring the bottoms of the boxes down to about the level of vinyl and still allow me to tighten the fans securely. But is there a better way? How is it normally done?
My apologies if this has already in covered in these forums; I was not able to find anything. Thanks very much!
...Dave
Dave Jones
Fort McCoy, Florida
davjones is offline   Reply With Quote
Old 04-30-2011, 01:09 AM   #2
Scared Electrician
Saturday Cowboy's Avatar
some j channel and trim around them like u would a window.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-30-2011, 08:28 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
IMO, bring the fan boxes themselves down to the level of the soffit (no extentions, use fan rated boxes). Use fan braces, 2X4's, something that solidly secures the fan box to the framing. Cut a hole in the soffit for the box to come through as you put it up. You can use J-blocks around the fan boxes for trim if you like, but you want the fan attached directly and solidly to the box and not the J-block.
Kyle
Old 05-03-2011, 12:35 PM   #4
Thanks to y'all for your help.
I thought about Saturday Cowboy's idea of just boxing around the fans -- of course it would work and be easy, but a square opening in the vinyl around a round fan bezel wouldn't be that great in terms of appearance.
So Kyle, I'll bring the fan boxes down 1/2" as you suggest and that'll be that.
Thanks again!
...Dave
Old 05-03-2011, 02:15 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Good luck ! I'm sure it'll look nice.
Kyle
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Moving Air Return from Floor Soffit to Ceiling Soffit mehaley HVAC 4 07-20-2008 12:00 PM
Soffit Running Thru Bathroom / Dropped Ceiling xlr8tn Building & Construction 3 01-23-2008 07:37 PM
big mess on vinyl floor installation thecanadian Flooring 1 03-19-2006 08:28 PM
Soffit installation question milano Roofing/Siding 4 02-04-2006 11:13 PM
