Ceiling Fan Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2008, 11:32 AM   #1
Ceiling fan installation
Looking to install a ceiling fan in a room that does not have a ceiling fixture currently. The room has a total of 4 outlets one of those is controlled by the switch. Can any one tell me with the wire configuration below if this is possible or will I have to run new wiring from a junction box.
At the switch: 2 white wires are tied together 4 red wires ties together and one is a pigtail to the bottom of the switch 1 orange wire comes from the box and is connected to the top of the switch.
At the outlet: top of outlet red and orange wire w/tab broken bottom of outlet has white single wire.
code requires conduit.
fleetdude1 is offline   Reply With Quote
Old 08-24-2008, 12:57 PM   #2
What is your plan here? Do you want to keep the switch outlet and add a switch for the fan? Or use the switch for the fan and eliminate the switched outlet? Is there attic space above? Will there be a light kit on the fan? Will you use a fan/light dimmer?
Super33 is offline   Reply With Quote
Old 08-24-2008, 03:58 PM   #3
Rewards Points: 338
fleetdude1, Super33 or a few of the other windy city electricians will probably be the best source for your residential pipe job. (see conduit vs. romex threads). I hope there's an attic above the space you're asking about. good luck, pete
petey_c is offline   Reply With Quote
Old 08-24-2008, 09:50 PM   #4
I will be using the old switch and eliminating the switched outlet. There is plenty of attic space above the room where the fan will be installed. The fan does come with a light kit and I will not be using a dimmer at all.
Thanks for your help
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 11:48 AM
Ceiling Fan Installation kennykenny Electrical 14 07-08-2008 11:57 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
ceiling fan installation PLEASE someone help finleygoddess7 Electrical 35 03-08-2008 10:41 PM
ceiling fan downrod extension installation smallcrpt Electrical 3 02-12-2007 03:14 PM
