Ceiling Fan Install With No Red Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 01:09 PM   #1
Rewards Points: 150
ceiling fan install with no red wire
so im looking to put ceiling fans with lights 2 of my bedrooms. but the current wire there is just white and black. not 14/3 wire... is there still a way to hook up?
fabian is offline   Reply With Quote
Old 02-24-2009, 01:19 PM   #2
plumbing contractor
PLUMBINGITALL's Avatar
Yes you just have to tie the blue and black wire from the ceiling fan together and tie it to the black wire from the light box. It will work fine but you will turn the light and fan on at the same time. But you can use the chain switch's to cut off the light or fan seperate.
PLUMBINGITALL is offline   Reply With Quote
Old 02-24-2009, 01:20 PM   #3
Res Ipsa Loquitur
Two possible scenarios come to mind-
1) The wires are unswitched (hot) all the time meaning white is neutral and black is hot- if so (without any changes) you would probably need to control the fan / fan light using pull chains on the fixture- you may also find a particular remote control fan that could do this with the right electronics.
2) the black and white are switched where the white is a switch leg and not marked. Is there a wall switch that powers it? Can be tested with tester.
In either case you cannot have what you want which I think is seperate switching of light and fan unless it is wired for seperate switched connections from wall switch to ceiling box. If wall switched then the switch operates both the fan and light together.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 02-24-2009, 01:39 PM   #4
We have 6 overhead fans/lights in the house & I installed different pull chains
The light pull chain has a clear dolphin ($1 on clearance)
The fan pull chain is a solid pull (factory supplied)
Very easy to tell which is which now
Old 02-24-2009, 01:50 PM   #5
Rewards Points: 150
in the rooms i want to put the light/fan in has a wall switch that triggers the ceiling light. single pole switch
Old 02-24-2009, 03:55 PM   #6
You will have to operate the fan and light from their pull chains or install a remote control.
220/221 is offline   Reply With Quote
Old 02-24-2009, 04:13 PM   #7
A lot of the higher end ceiling fans (Casablanca, Minka) come with wall controls and/or remotes that only require one hot wire. There are probably some cheaper brands that have the same thing, but I've found they will usually start vibrate or make some irritating noise sooner or later. I've had a Casablanca Stealth in my computer room for over 15 years that runs as quiet as the day I installed it.
surrogate is offline   Reply With Quote
Old 02-25-2009, 06:47 AM   #8
Rewards Points: 150
thanks everyone for the replies.
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
Is using a ground wire as neutral wire safe? Head Fred Electrical 9 12-18-2008 02:37 PM
no ground wire in ceiling OC650 Electrical 12 04-01-2008 12:46 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Ceiling fan Medallion, any tricks to install? Bacardi 151 Interior Decorating 5 11-08-2007 08:09 PM
