Old 06-01-2011, 10:47 PM   #1
Learning by Doing
Leah Frances's Avatar
Ceiling Fan install - finally something I did right...
I spent some time today proving to myself that you do use geometry after grade school in order to get my oct-box for a future ceiling fan perfectly centered in the room and in the center of one of the tin tiles. Came out well and just as anally retentive as it sounds.
It occurred to me that I had pulled 12/2 through the joists for the future ceiling fan. Thankfully, I thought about this before I closed up the ceiling. I happened to have some 12/3 on hand and it was easy enough to use the 12/2 to pull the 12/3.
I'm super pleased that I thought about it before it was a major PITA to change. For once.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-01-2011, 10:51 PM   #2
Licensed electrician
You mean the 12-2 wasn't stapled?
Congrats.
Old 06-01-2011, 11:00 PM   #3
Learning by Doing
It was just run through the joists, no staples.... yet.
Old 06-02-2011, 09:06 AM   #4
Do you already have the fan(s) you plan to install? I found out the hard way that some are NOT designed to be installed on the typical octagonal fan box. Mine (Hunter brand) came with a huge lag screw and some washers to attach a pancake box directly to a rafter or to a cross-piece of 2x4 between two rafters. That, and having a 12/12 pitch ceiling, made it "interesting" to install them.
Ceiling Fan Install power source at fixture uaw239gm Electrical 17 01-09-2011 09:50 PM
Ceiling fan install ramage78 Electrical 24 01-05-2011 11:23 AM
Porch ceiling fan - how to do nice install? Leah Frances Electrical 4 07-13-2010 07:47 PM
VERY Quick Ceiling Fan install question! Fox Electrical 10 07-02-2010 05:03 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
